07 2.2 lt p0340
Old Mar 20, 2017 | 11:57 PM
Hadenroesler98's Avatar
07 2.2 lt p0340
Okay guys, so I have a 2007 lt with the 2.2 ecotech in it. I'm getting a check engine light reading as p0340. I replaced the sensor and I'm still getting then CEL. Car has brand new plugs. Only mods are in intake and a cat back. I can't seem to get this figured out. Car turns over and misfires but will not start unless I keep hitting the gas pedal then it finally sputters and starts then runs just fine after. Any thoughts or suggestions?
Old Mar 26, 2017 | 10:32 AM
Foximus's Avatar
It will misfire because it still thinks the camshafts are at different positions. You replaced the sensor, I would go back and check the sensor wiring for continuity to make sure the harness isn't damaged next.
Old Mar 26, 2017 | 10:34 AM
Alright so I actually got it figured out!
