14.0:1 ratio?
i remember reading some were, i think it was howstuffworks.com,
said the best air to fuel ratio is 14.0:1, is that no good for a 4 cylinder, this is my first 4 so im not sure
Not if you use if properly. Stupid people blow up their engines with NAWWWZZZ.
Last edited by USMCFieldMP; Jun 25, 2008 at 07:39 AM. Reason: Automerged Doublepost
True.
Not True.
...and actually... 14.7 is the perfect AFR.
F/I is a whole different ball game.
Not True.
Last edited by USMCFieldMP; Jun 25, 2008 at 07:54 AM. Reason: Automerged Doublepost
Forced Induction...
...Supercharger and/or Turbo.
Instead of asking so many n00b questions...
http://justfuckinggoogleit.com/
A lot of the info you are looking for can be found very very easily. That's why there is Google, Yahoo, and the CobaltSS.Net search button!
if your asking if that AFR has ever been hit by a 2.2, then yes...every single L61 out there has hit that AFR....lean cruse,decel, ect....
if your referanceing 14:0 at WOT then i certonally hope not. 14:0 doesnt have enough fuel to support much advance or compression. not enough just for cooling and knock resistance eaither.
you can push a well tuned NA car into the mid-high'ish 13's at WOT but not much beyond that before you need more octane or **** lets go.
at that AFR your power will be suffering quite a bit because of a few things, one, you'll have to pull so much timeing to keep kr out of it the car simply wont want to move. Two even when you find a sustainable advance number, with so little fuel to make energy out of, there still wont be dick for power.
