2.0 map sensor in a 2.2?
Yup, u don't need this conversion, and wouldn't benefit u at all. Ur maf is at a post intercooler position so the iat it's reading is iat2 bc of it's position in you set up. Had it been in the turbos intake I would be iat1 as it's pre intercooler. So if u wanna see ur iat2's just use a scan tool or interceptor to watch ur iat's
ok, so im still a little confused about this. the 2.5 bar MAP sensor has to be rewired to where the stock MAP sensor was. but reading in Genes build it talks about wiring it to the MAF so the IAT2s can be read. sooo i gotta splice into the MAF? my set up is blow thru.....haha, blow..lol. anyways can someone please clarify this. i got the lines for the meth ran and all thats left is to get the MAP sensor and fill up the tank and tune
yes, the map sensor replaces your existing one, so you wir that up, and the iat wire gets wired to your MAF's iat wire, so it replaces it, so now what your ecm thinks is IAT1 is really iat2, so you can monitor it on a scan tool, and vince can see it while tuning
alright, got ya. and the LSJ map sensor is a 3 pin right? i was looin at my stock sensor and it was a 3 pin. i just wanna make sure everything goes correct. can you tell me which wire i have to wire to the MAF? any photos of wat wires to cut?
nope. The 2.5bar MAP/IAT2 is not a 3 pin, as it is both a MAP and IAT2 sensor, whereas on the L61 the sensor is solely a MAP sensor. (the LSJ one is either 4 pin or 5 pin, cant remember)
