2.2 cams
At a minimum I would get valve springs and a tune. If you're planning on taking the motor beyond 7500 rpm then you would need to add neutral balance shafts to that list as well.
I've been contemplating cams myself but not sure which ones I want to go with for my build
i m cammed stg2 N/a and a supercharged
all this is stock head.
you need a tune and i suggest a TB from LSJ
http://www.youtube.com/watch?v=RZzLqm_b3NI
Been stage 1 cammed several years now. I have issues with sometimes wanting to stall and when running the ac I wants to at all when stopping. I have the 2.4 tb and manifold. I been thinking about the lsj but will that fix the problem idk
yes he did at 80%. still minor issue but overall, it improved big time
it is still fragile when it is not warm up.
every car are differents. i have reflashed 2 SC cammed stg3 NA and both run fine.
power increase is very noticable compare to a body that run a similar setup.
@ copson: yes a LSJ TB can improve your idling. it did with mine.
with 2,4 TB its was horrible. lsj TB improve a lot without touch up
but one day. i thing i have seen that my fuel trim was lean at idle.
do u have a wideband? you can see if you are lean.
do you have a fidanza flywheel? rpm fall faster and maybe harder to get right
a good .DTL is idling - WOT - cruise
