2.2 dual exhaust
So just tossing in a Y splitter and some extra piping is going to HURT your car. Can't be too much though, but if you're going to turbo it like you said in your original post- you're going to be running ALOT more through the pipes. I'd just run the pipes straight as hell, and not worry about the visuals.
Haha, they will only be seeing you're back end up close for a couple seconds before you disappear...
1. Weight - Adding larger piping and at the same time MORE piping will increase the weight of the vehicle. The more weight a vehicle has, effectively, the harder the engine has to work to move the vehicle.
"adding 1 or 2hp is like removing a brick from your back seat. Go put a brick in your backseat next time you drive and tell me if you feel the difference."
lol
the other option is to just hang the muffler and tip back there. inother words, have one actual muffler, and the other just kinda "sit" there, if you are that worried about the performance.
jpizzle had a set put on his car, and the only issue i have is that the plastic on the back, it is obvious where it was cut.
z28addiction
Sep 28, 2015 12:03 AM
