2.2 ecotec finally blew
My motor on my covalt finally blew n went. To to local junk yard to look for a motor and could only find a 2.2 ecotec of a 2004 cavi and a 2.2 ecotec from a 07 cobalt. N was wondering if any of these two motor will work
The cavy motor will not work at all the tach signal is wrong, also you would need to sway your thermostat housing and oil pan. The 07 should work unless there is a difference in the head I dont know about.
Or he could use the 07+ head, leave the cam sensor in but dont plug it in 9there's no plug for it anyways) and use the ignition setup from his car. He would hav eto use the ignition for his car anyways because that changed in 07.
So the 07 l61motor will work I just have to not connect the cam sensor n use my old ignition system, or could my old head bolt on the 07 motor.and also im planning on using the ss supercharger would it be diffrent since 07 l61 motor has the cam sensor. And would the car run fine with the cam sensor not plugged in
