2.2 ecotec finally blew
Old Nov 14, 2011 | 04:05 PM
streetrush's Avatar
My motor on my covalt finally blew n went. To to local junk yard to look for a motor and could only find a 2.2 ecotec of a 2004 cavi and a 2.2 ecotec from a 07 cobalt. N was wondering if any of these two motor will work
Old Nov 14, 2011 | 04:17 PM
j27-2's Avatar
what year is your car
Old Nov 14, 2011 | 04:18 PM
bbrewbaker's Avatar
Based on his previous posts he has a 06.
Old Nov 14, 2011 | 04:25 PM
streetrush's Avatar
Its a 05
Old Nov 14, 2011 | 04:39 PM
streetrush's Avatar
Its a 05
Old Nov 14, 2011 | 04:49 PM
IonNinja's Avatar
If your head from the stock motor is still good you should be able to use the 04 block. Neither will be direct bolt on though
Old Nov 14, 2011 | 06:06 PM
streetrush's Avatar
Can u explain why neither motor will bolt on n would u know what other cars have the l61 that would bolt on
Old Nov 15, 2011 | 12:17 AM
Leafydialupking's Avatar
The cavy motor will not work at all the tach signal is wrong, also you would need to sway your thermostat housing and oil pan. The 07 should work unless there is a difference in the head I dont know about.
Old Nov 15, 2011 | 12:30 AM
j27-2's Avatar
you can not use the 07 l61. 07+ use a 58x reluctor wheel
Old Nov 15, 2011 | 12:32 AM
The 05+ use what reluctor wheel then? They sure as hell dont use the 6+1 of the cavy. I've been under the impression that every 05 and newer ecotec uses the 58x wheel.
Old Nov 15, 2011 | 12:34 AM
1LowLS's Avatar
only thing different on 2007 electrical wise is the cam sensor in the head.If his head is still good,he could use the 2007 block and bottom end.
Old Nov 15, 2011 | 12:35 AM
Or he could use the 07+ head, leave the cam sensor in but dont plug it in 9there's no plug for it anyways) and use the ignition setup from his car. He would hav eto use the ignition for his car anyways because that changed in 07.
Old Nov 15, 2011 | 12:49 AM
1LowLS's Avatar
correct and he would make a little more power from the 2007 head being a gen 2(slightly larger ports)
I believe the cams are slightly different but not positive on that one.
Old Nov 15, 2011 | 06:36 AM
streetrush's Avatar
So the 07 l61motor will work I just have to not connect the cam sensor n use my old ignition system, or could my old head bolt on the 07 motor.and also im planning on using the ss supercharger would it be diffrent since 07 l61 motor has the cam sensor. And would the car run fine with the cam sensor not plugged in
Old Nov 15, 2011 | 07:23 AM
Yes the car will run fine with the cam sensor not plugged in. In your 05 the ignition system is actually the cam sensor. Its complicated to explain how it works, but it does.
Old Nov 15, 2011 | 05:59 PM
07cobaltguy's Avatar
I believe the 07 crank wheel is also differnt than previous year L61's, because of the change to the E37 ECU. I think, dont quote me on it.
Old Nov 15, 2011 | 08:10 PM
1LowLS's Avatar
Not that I recall.I believe it was only the intake cam with the sensor on it.
06MetallicBalt
Jul 20, 2025 08:47 PM
Trav3480
Oct 1, 2015 08:17 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
MrInsanityWolf
Sep 29, 2015 04:54 PM
Trav3480
Sep 28, 2015 02:46 PM
