2.2 L Supercharger
Old Jan 28, 2006 | 08:26 PM
Brian MP5T's Avatar
Originally Posted by YellowLT
My friends Cav with the GMPP dealer installed doesn't void his factoryt warranty that was my original point, and that's what i want for my balt
A GMPP what exactly?
Old Jan 28, 2006 | 08:35 PM
YellowLT's Avatar
The GMPP supercharger kit for the 2.2lecotec he has
Old Jan 29, 2006 | 01:56 AM
Halfcent's Avatar
I'm old school
I understand your desire to have the GM kit. It will be expensive, and it will not produce as much power as you could get for that same amount of money. But you do get to keep a warrenty and have it serviced by Goodwrench, so I understand.
However, the stage kits for are for the LSJ engine. They will not work on the L61 engine. Sure, you can try it, but then all that stuff I just said about keeping a warrenteed engine goes right out the window.
Old Jan 29, 2006 | 09:30 PM
Roadrunner's Avatar
isnt there a procharger one in the works too?
Old Jan 29, 2006 | 10:12 PM
FLCobalt's Avatar
Rsm racing kit is Very expensive jeeze. Do super chargers always tend to cost more then a turbo?
Old Jan 29, 2006 | 10:40 PM
brianm01's Avatar
I was just at the Harrisburg Auto Show yesterday and the GM performance rep told me that they increased the output #'s for the 2L turbo motor another 5HP and 5Ft lb of torq 265 Hp and 265 torq, thats sweet. He also said to look for more turbocharged products to come from GM.
Old Jan 29, 2006 | 11:20 PM
philco_3's Avatar
Proud Playstation 3 Owner
here we go guys
2.2 Ecotec Supercharger - 17800003
GM LIST: $3,388.00
GMPARTSDIRECT.COM: $2,845.92
Old Jan 30, 2006 | 07:30 AM
Brian MP5T's Avatar
$$$$ Bling
Old Jan 30, 2006 | 08:04 AM
avro206's Avatar
sneaky--you forgot one important item. The Solstice uses a RWD version of the ecotec. So even if there is a crate engine you couldn't drop it in. Many componenets would not work.
You could use some parts for sure but not the entire engine.
Also, whats up with that low 5300rpm hp peak of the GXP?? Thats werid. Should be over 6000rpm
Old Jan 30, 2006 | 08:07 AM
3fo893013L's Avatar
i'm sure something could be done to make it work, otherwise it would make for a good rwd cobalt conversion
Old Jan 30, 2006 | 08:08 AM
  #36
Brian MP5T's Avatar
If it's turbocharged, an engine will usually fall off at redline where a SC will scream linear.
Old Jan 30, 2006 | 10:24 AM
  #37
Halfcent's Avatar
I'm old school
Originally Posted by philco_3
here we go guys
GM LIST: $3,388.00
Careful. I think thats the kit for the Cavalier/Sunfire, which is not compatible with the Cobalt. The Cobalt kit is it's own separate thing, and has not been released yet.
Old Jan 30, 2006 | 11:26 AM
  #38
Blown Ecotec's Avatar
really? because from my understanding, it will be exactly the same kit that will work, it was just long overdue. a call to gm technical support will confirm this one. its the same kit they used in the gm performance build, on a cobalt.
does anyone have pricing for the other kits mentioned?
Old Jan 30, 2006 | 11:34 AM
  #39
c7015's Avatar
wow look at the redline on the Turbo Eco ...I would say its safe to assume that this engine will have more than 260 BHP
Old Jan 30, 2006 | 04:34 PM
  #40
brandon11482's Avatar
By the way, does anybody know what that extra pump on the lower left side of the accessory drive is? It has a drive belt all its own. It could be a power steering pump, but that would mean no more electric power steering.
I beleave that is the second belt-driven fuel pump that the article mentioned...
Taken from article: "A high-pressure, returnless fuel system is employed. It features a high-strength stainless steel fuel line that feeds a variable-pressure fuel rail. Direct injection requires higher fuel pressure than conventional fuel injected engines and an engine-driven high-pressure fuel pump is used to supply up to 1,276 psi (150 bar) of pressure. The system regulates lower fuel pressure at idle — approximately 752 psi (50 bar) and higher pressure at wide-open throttle. The cam-driven high-pressure pumps works in conjunction with a conventional fuel tank-mounted supply pump. "
Not 100% sure, just what i got from it...
Old Jan 30, 2006 | 06:45 PM
  #41
Halfcent's Avatar
I'm old school
Good thinking, but that isn't it. The part you highlighted says "Cam Driven", which means its on that mounting pad on the cylinder head where the Cavalier Ecotecs have their power steering pumps. So I still want to know what that thing is.
Old Jan 30, 2006 | 08:17 PM
  #42
ahh yea...*shrugs* i dunno...
Old Jan 30, 2006 | 08:46 PM
  #43
avro206's Avatar
I was alwasy under the impression that superchagers make great power off idle while turbos take longer to build boost but have more power at high rpm. Where did I go wrong??
Old Feb 8, 2006 | 04:26 PM
  #44
giovanhalen's Avatar
There is a reason GM offers the sc with a warranty, your engine can handle it without modifications. If you were to put a turbo on and try and get 260hp like the Solstice engine and not worry about damaging the engine, you would need to rebuild the engine. Look at all the changes they made to that engine.
Old Feb 8, 2006 | 04:51 PM
  #45
Brian MP5T's Avatar
At almost redline, a turbo engine will taper off unless steps have been taken to reduce this effect.
Old Feb 21, 2006 | 01:58 PM
  #46
SlateFox's Avatar
will that turbo fit on our cobalts?
Old Mar 9, 2006 | 05:11 PM
  #47
05_cobalt's Avatar
To whom it may concern, Vortech released a stg. 2 supercharger for the 2.2L ecotech. That is rated at 85hp. @ 10psi, which ain't bad numbers at all.
Old Mar 11, 2006 | 12:27 PM
  #48
ryankcobalt's Avatar
would the turbocharger kits made for the 2005 cavy work for my 2.2L cobalt since they both have a 2.2L Ecotech? I dont see any reason why they wouldnt.
Old Mar 11, 2006 | 12:50 PM
  #49
3fo893013L's Avatar
um I don't know... maybe we should ask the expert...
want my honest opinon? same motor, different routing of plumbing and would need some custom work. Nothing is ever out of the question with a little bit of thought and money/time.
Old Apr 7, 2006 | 02:52 PM
  #50
YellowLT's Avatar
The cav doesnt fit it has clearance issuses. I read it in the Build book there is a bunch of grinding and cutting involved.
