2.2 L61 SC question
Standard Bolts Needed (Not GM)
LSJ 1 Bar MAP To Intake Manifold M6 x 1.0 x 25 (Qty 1) LSJ Intake Manifold Mount Bracket To Intake Manifold M10 X 1.50 x 50 (Qty 1) LSJ Rear IC Pump Bracket To Intake Manifold Mount M8 X 1.25 X 25 – (Qty 2) LSJ Front IC Pump Bracket To Rear IC Pump Bracket M8 X 1.25 X 35 – (Qty 2) LSJ Idler Pulley To Block M10 X 1.50 x 75 (Qty 1) LSJ Idler Pulley To Alternator Bracket M8 x 1.25 x 25 LSJ Intake Manifold To Block M6 x 1.0 X 75 (Qty 2) LSJ Alternator Bracket To Block M8 X 1.25 X 130 (Qty 3) LSJ SC Bypass Valve To SC M8 X 1.25 X 20 (Qty 2) LSJ Tensioner Lower To Alternator Bracket M8 x 1.25 x 35 LSJ Tensioner Upper To Alternator Bracket M8 X 1.25 x 40… not standard bolt though. Has to be metric hex socket bolt. LSJ SC Reservoir Bracket To SC M6 x 1.0 x 15 (Qty 2) LSJ SC Reservoir To SC Reservoir Bracket M6 x 1.0 x 15 (Qty 2) on these bolts im need to buy them looking at boltdepot.com, what type bolts, hex? or does it really matter so long as the "M6 x 1.0 x 15 " is there |
Honestly it shouldnt matter man just deoends what would be an easier tool for u to use to put them in.. the only hex bolts i am using is the sc to mani ones
i didnt think it would be a big problem but i figured id ask before i ordered...
Yeah dont trip as long as the threading and the length is correct u should be fine
i thought the map sensor that went on the lsj intake manifold was a 3 bar...or is that the one that goes on the supercharger?
no its a 2.5 bar on the mani
and a 1 bar on the sc |
Originally Posted by Fonzi1289
(Post 4646642)
Nah the guy right above me thought it was a 3 bar MAP on the mani
oh well i think i still did, you said its a 2.5 bar? the very first one i listed?
anywho here is a responce from boltdepot, i need to make sure i buy the right strength bolts, dont want them to snap Grade 8 steel is a grade of steel used exclusively on inch size bolts, but all of the fasteners you list are metric bolts. Sometimes when people talk about “grade 8” metric bolts they are referring to metric grade 8.8 bolts, but grade 8.8 is similar to grade 5 inch size bolts not grade 8. Other times “grade 8” metric is referring to metric grade 10.9 bolts that are similar to inch size grade 8 bolts (though not exactly the same). You can find our full selection of metric hex bolts here: http://www.boltdepot.com/metric-hex-bolts.aspx, and metric socket products here: http://www.boltdepot.com/metric-socket-products.aspx. If you have any other questions or concerns, please don’t hesitate to call or email. |
bump,,, answer for checking the previous links
WHat r u asking?
Boltdepot.com
Just asked em for the strongest ons cause i am using them for automotive purposes |
i gotcha, i email them back telling them these are the ones i want, the strongest you got now go find them
Haha yep. or if u go to the sections it tells u which ones to use for automotive purposes but that works just fine
alright, well i also just bought the supercharger gasket...so that leaves
bolts tune wideband pod(S) 42#ers+harness i have an endplate i want to drill for dual pass what else... |
Um heat exchanger.. mani to head gasket, umm..?
oh yeah i need those, .... not too much else otherwise various hoses
Yeah um intake
got that
