2.2 L61 SC question
Old Jan 30, 2010 | 12:11 AM
ipwncivics's Avatar
2.2 L61 SC question
Standard Bolts Needed (Not GM)
LSJ 1 Bar MAP To Intake Manifold
M6 x 1.0 x 25 (Qty 1)
LSJ Intake Manifold Mount Bracket To Intake Manifold
M10 X 1.50 x 50 (Qty 1)
LSJ Rear IC Pump Bracket To Intake Manifold Mount
M8 X 1.25 X 25 – (Qty 2)
LSJ Front IC Pump Bracket To Rear IC Pump Bracket
M8 X 1.25 X 35 – (Qty 2)
LSJ Idler Pulley To Block
M10 X 1.50 x 75 (Qty 1)
LSJ Idler Pulley To Alternator Bracket
M8 x 1.25 x 25
LSJ Intake Manifold To Block
M6 x 1.0 X 75 (Qty 2)
LSJ Alternator Bracket To Block
M8 X 1.25 X 130 (Qty 3)
LSJ SC Bypass Valve To SC
M8 X 1.25 X 20 (Qty 2)
LSJ Tensioner Lower To Alternator Bracket
M8 x 1.25 x 35
LSJ Tensioner Upper To Alternator Bracket
M8 X 1.25 x 40… not standard bolt though. Has to be metric hex socket bolt.
LSJ SC Reservoir Bracket To SC
M6 x 1.0 x 15 (Qty 2)
LSJ SC Reservoir To SC Reservoir Bracket
on these bolts im need to buy them looking at boltdepot.com, what type bolts, hex?
or does it really matter so long as the "M6 x 1.0 x 15 " is there
Old Jan 30, 2010 | 12:19 AM
Fonzi1289's Avatar
Honestly it shouldnt matter man just deoends what would be an easier tool for u to use to put them in.. the only hex bolts i am using is the sc to mani ones
Old Jan 30, 2010 | 12:21 AM
ipwncivics's Avatar
i didnt think it would be a big problem but i figured id ask before i ordered...
Old Jan 30, 2010 | 12:29 AM
Fonzi1289's Avatar
Yeah dont trip as long as the threading and the length is correct u should be fine
Old Jan 31, 2010 | 09:47 AM
BlackCobalt707's Avatar
i thought the map sensor that went on the lsj intake manifold was a 3 bar...or is that the one that goes on the supercharger?
Old Jan 31, 2010 | 10:52 AM
Fonzi1289's Avatar
no its a 2.5 bar on the mani
and a 1 bar on the sc
Old Jan 31, 2010 | 10:51 PM
ipwncivics's Avatar
did a miss type somewhere?
Old Jan 31, 2010 | 10:52 PM
Fonzi1289's Avatar
Nah the guy right above me thought it was a 3 bar MAP on the mani
Old Feb 1, 2010 | 01:23 PM
ipwncivics's Avatar
oh well i think i still did, you said its a 2.5 bar? the very first one i listed?
anywho here is a responce from boltdepot, i need to make sure i buy the right strength bolts, dont want them to snap
Grade 8 steel is a grade of steel used exclusively on inch size bolts, but all of the fasteners you list are metric bolts. Sometimes when people talk about “grade 8” metric bolts they are referring to metric grade 8.8 bolts, but grade 8.8 is similar to grade 5 inch size bolts not grade 8. Other times “grade 8” metric is referring to metric grade 10.9 bolts that are similar to inch size grade 8 bolts (though not exactly the same). You can find our full selection of metric hex bolts here: http://www.boltdepot.com/metric-hex-bolts.aspx, and metric socket products here: http://www.boltdepot.com/metric-socket-products.aspx. If you have any other questions or concerns, please don’t hesitate to call or email.
Old Feb 4, 2010 | 09:26 PM
ipwncivics's Avatar
bump,,, answer for checking the previous links
Old Feb 4, 2010 | 09:34 PM
Fonzi1289's Avatar
WHat r u asking?
Old Feb 4, 2010 | 09:37 PM
ipwncivics's Avatar
if what they said is correct and which section to get the bolts from, where did you get your bolts the ones that cant be found around town
Old Feb 4, 2010 | 09:38 PM
Fonzi1289's Avatar
Boltdepot.com
Just asked em for the strongest ons cause i am using them for automotive purposes
Old Feb 4, 2010 | 09:41 PM
ipwncivics's Avatar
i gotcha, i email them back telling them these are the ones i want, the strongest you got now go find them
Old Feb 4, 2010 | 09:43 PM
Fonzi1289's Avatar
Haha yep. or if u go to the sections it tells u which ones to use for automotive purposes but that works just fine
Old Feb 4, 2010 | 09:46 PM
ipwncivics's Avatar
alright, well i also just bought the supercharger gasket...so that leaves
bolts
tune
wideband
pod(S)
42#ers+harness
i have an endplate i want to drill for dual pass
what else...
Old Feb 4, 2010 | 09:54 PM
Fonzi1289's Avatar
Um heat exchanger.. mani to head gasket, umm..?
Old Feb 4, 2010 | 10:55 PM
ipwncivics's Avatar
oh yeah i need those, .... not too much else otherwise various hoses
Old Feb 4, 2010 | 10:58 PM
Fonzi1289's Avatar
Yeah um intake
Old Feb 6, 2010 | 05:21 PM
ipwncivics's Avatar
got that
DarrenGC
Dec 24, 2021 01:55 PM
brandon04
Oct 21, 2015 07:04 AM
ThoR294
Oct 4, 2015 08:44 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
