2.2L Cooling System Help!!
Old Jan 23, 2012 | 03:53 PM
07cbaltLS's Avatar
I gotta pull the front end off tonight and see what all got messed up the other night when I slid into a ditch and tweaked the drivers side bottom radiator mount. Anything I should be looking for specifically or is it all pretty much straight-forward? I tried searching for answers, but didn't find anything pertaining to my situation.
Old Jan 23, 2012 | 07:31 PM
nhanson's Avatar
depends how hard you went in...i would maybe look at an alignment too. Just check everything over: oil pan, trans mounts, radiator, AC condenser.
Old Jan 23, 2012 | 08:35 PM
cleanxfe's Avatar
^x2
Old Jan 28, 2012 | 04:30 PM
07cbaltLS's Avatar
Ok, everything looks fine. I broke a mounting tab off the bottom of the rad and bent the mount on the subframe.. Checked over everything else and it all appears to be fine. Getiing the P0480 code saying cooling fan 1 circuit has a malfunction.. Replaced the fuses and checked power to the relays, but it still trips the fuses for cooling fan 1 and 2...
Old Jan 28, 2012 | 04:39 PM
nhanson's Avatar
Check for grounded out wires
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 04:49 PM
ThoR294
Oct 4, 2015 08:44 PM
