2.2L Spark Plugs
Old Jun 10, 2008 | 08:20 PM
jbenso4's Avatar
2.2L Spark Plugs
Just woindering what the best gap and the best plug for a 2.2l would be with my mods mods are in sig....plz share thoughts.
Old Jun 10, 2008 | 11:00 PM
CobaltLT's Avatar
You don't need any unless you plan on doing some serious mods. Stock is fine for now.
Old Jun 11, 2008 | 04:24 PM
XM15's Avatar
OEM AC Delco plugs gapped at 0.040" will be fine.
Old Jun 12, 2008 | 04:06 AM
Foximus's Avatar
is 0.040 teh best gap to use with any aftermarket plug, NGK, Autolite, etc?
Old Jun 12, 2008 | 05:28 PM
XM15's Avatar
Depends on your setup. But for a 2.2 with just bolt-ons, 0.040 will be the gap to use.
Old Jul 22, 2008 | 03:09 PM
PSPCobalt's Avatar
How About for a stock 2.2 will the same gap be fine
Old Jul 23, 2008 | 12:27 PM
drivernoverdrive's Avatar
plugs
yep, pretty much all the same unless you are starting to run some serious hp or change up some ignition parts
Old Jul 23, 2008 | 02:22 PM
massivematt's Avatar
Bosch Platinum +4 plugs rock. Either get those or the new IR fusion bosch plugs.
Old Jul 23, 2008 | 04:52 PM
Spanky's Monkey's Avatar
i kinda like the stock plugs and they ain't bad on the juice either. i changed out for the ngk 2 step colder and hated the power reduction on pump gas so i swapped back. changed out the stockers once and they looked like damn near new. only reason i changed em is cause one got over torqued and cracked on me. stocks iradium ftw!
Old Jul 24, 2008 | 05:55 PM
plugs
Well, I have heard that Bosch plugs don't last...I am actually running pulse plugs in mine....check em' out at
www.pulstarplug.com
they have increased the response time and efficiency of my cobalt....but a bit pricy
DarrenGC
Dec 24, 2021 01:55 PM
ThoR294
Oct 4, 2015 08:44 PM
717ssbalt
Oct 2, 2015 04:01 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
