2.4 intake manifold swap
does the 2.4 manifold swap show a big improvement? or is it just blowing $200 for a slight gain?
into? the 2.2?
bump, how can i get this to work on a 2008 WITHOUT SAI
it has good gains without a tune imo. but with a tune it will be a lot better obv. but its not a total waste if your trying to get some decent power for cheap. it pulls a lot harder past 4000 then the regular manifold
Originally Posted by bryce712
(Post 3038458)
You will definately see an increase in power. It will shift the power band up a bit, but most people don't seem to mind that.
Originally Posted by 2006RedCobaltSS
(Post 3038470)
well.. in your perspective, should i get the 2.4 manifold swap or get a lowering kit? both are about the same amount.
Originally Posted by XM15
(Post 3038472)
You can make your own manifold "kit" by buying all the parts separately. Its alot cheaper that way. I believe it is in the neighborhood of $150. |
i have that swap on my 2.2 i would rather get the lowering kit if i could go back. and i also had a tune done to my car lil inprovment but lil
its preference really. want a little more power go with the manifold. want some show and a little performance lower the car
alright, so i've decided to order the parts for the manifold. i have on my list to order as follows:
2.4 manifold PVC seal TB Seal extended brake hose do i need the adapter plate and seal for my 2007 cobalt? or will it bolt on directly without it? |
im not sure i havent looked at the directions in awhile you talking bout for the throttle body ?
This is the best mod you can do for your car for the price. Get an exhaust and intake and complete the package. Or, lowering is always fun and just about never lets you down.
Just don't expect a world of difference. But, I'd say the only other cheap mod better than this is no2. |
Will somebody just make a sticky on this topic already.
i still need info about an 08 2.2 without sai
im looking at this, cai, and full exhaust (header/dp/catback) |
i could have sworn we alrady talked about this a little while back...
probably, i just miss a lot of discussion cuz i dont have access to a computer til 7th hour and then home after that
oh...okay
yea.... so can it be done?
get the manifold then the springs to be honest the manifold i felt was the most noticable add on i have gotten so far its easy to put in to. it was worth it for me
do i need the adapter plate to install the 2.4 mani on my 07 cobalt?
not sure myself, havnt looked into, someone will chime in and hook you up with the answer
Yes it can be put on a car with SAIR, the intake manifold has nothing to do with the SAIR system.https://www.cobaltss.net/forums/how-guide-43/2-4-intake-manifold-install-2008-2-2-a-135051/ <<<<<<<<My 2008 w/SAIR
2007 you dont need the adpater. the part numbers are around here somewhere. If everyone else is lazy maybe Ill look them up later. I too am getting tired of seeing so many threads regarding this mod. Please just use search a little bit guys....Weve been over all of this at least a dozen times and there are at least 2 how-tos. |
and Facelesskaos made a parts list to get all the parts for cheap.
I posted them as well. The CED kit is a waste of money if youve got an 07/08 (and 05/06 if you really get down to it :) )
| All times are GMT -4. The time now is 03:09 AM. |
