2007 2.2L Cobalt High Idle Problem
Old Sep 1, 2009 | 04:53 PM
JTLucas's Avatar
I have an 07 Chevy Cobalt last night I cleaned the throttle botty with throttle body cleaner while the battery on the car was off and now my car is idling sometimes at 3k and sometimes at 2k. Any ideas everything under the hood is secured such as hoses clamps and all.
Old Sep 1, 2009 | 06:27 PM
09TcSedan's Avatar
i did the same thing,and i took both of my o2 sensors out.so i had to replace both of them
Old Sep 8, 2009 | 05:01 PM
JTLucas's Avatar
did this cure the problem with the high idle
Old Sep 8, 2009 | 05:22 PM
arkkornkid's Avatar
did you remove the TB when you cleaned it? if not, then you had the cleaner in the intake when your car's ecu was resetting from the battery being off the car.... at least that'd what it sounds like to me.
You might try disconnecting the battery again for a while, then reconnect and let the car idle for 5 minutes on it's own, don't touch the accelerator. Then go for a drive and see if all is well.
Old Sep 8, 2009 | 05:26 PM
09TcSedan's Avatar
yup,i replaced both of them and it was good.i had 2 exhaust leaks tho as well.but i clean my TB and then the high idle came on.so i fixed the leaks and had to replace both of the o2 sensors and the high idle went away.no idea which problem led to the next
CobaltSS 16
Sep 12, 2015 02:43 PM
Sean Cummings
Sep 11, 2015 09:35 PM
Adam144
Sep 3, 2015 07:48 PM
Stardustolol
Sep 2, 2015 09:59 AM
