2007 L61 CAMS help
Old Feb 4, 2017 | 11:28 PM
hahiggi's Avatar
2007 L61 CAMS help
Hello I am new here to the forum
I have a 2007 L61 engine which is the year they added the sensor to the intake camshaft (I am sure you all know). Are they any solutions to be able to run performance cams in this year engine or are we all just basically S.O.L. I know no place sells performance cams aftermarket with the sensor but is there anywhere you can buy a blank cam with the sensor or is there any way to bypass the sensor so to speak. Any help would be greatly appreciated.
Old Feb 5, 2017 | 10:32 AM
Buy lsj cams, cut them, press the reluctor wheel on, done.
Old Feb 6, 2017 | 10:00 AM
hahiggi's Avatar
But then won't the sensor be missing? Or do lsj cams have the sensor as well?
Old Feb 6, 2017 | 11:41 AM
Did you miss the part where i said press the reluctor on?
Old Feb 6, 2017 | 11:44 AM
Lsj cams are longer than yours so you have to cut them and then line up the reluctor wheel and press it on.
