2008 LE5 manifold revisited.
Old Apr 1, 2009 | 08:08 PM
Kodatech's Avatar
Ok im starting a new thread because the other ones are kind of old and lifeless. I know...the 2007 is the one to get...but If i got a 2008 one for FREE, is it completely worthless? Will it add any HP if I put it on? Im just saying....dude...its free....if it is worth 3HP its worth it for free....Anyone done it?
Last edited by Kodatech; Apr 2, 2009 at 08:31 PM. Reason: Updated...now with pics at bottom of page.
Old Apr 1, 2009 | 08:09 PM
MachiBLue's Avatar
shouldnt they be the same?
Old Apr 1, 2009 | 08:39 PM
Kodatech's Avatar
They are different...but they are also BOTH different from the L61 manifold.
Old Apr 1, 2009 | 11:39 PM
Red07SSNA's Avatar
https://www.cobaltss.net/gallery/fil.../08_intake.jpg
The real question we haven't gotten an answer on is why did GM replace the 06-07 mani on the 2.4L?
Was it a cost savings? -- The 08 is a lot cheaper to buy (and produce)
Was it because of higher 08 emissions requirements?
Was it better on factory evaluations then the earlier version?
Old Apr 2, 2009 | 01:38 AM
Nato09's Avatar
the 07 looks bigger than the 08.. maybe its just the angle though
Old Apr 2, 2009 | 03:11 AM
warrenb213's Avatar
well lets find a stock 08 2.4 that's dyno'd.
that way we can clear up how much less power the 08's have due to the changes.
Dunkinuts has an 08 that dyno'd 159whp 156wtq (stock, Dynojet)
Zdeuce4 156 whp, 154 wtq Verified STOCK i'm pretty sure he's pre-08.
Old Apr 2, 2009 | 04:08 AM
Jaemon52's Avatar
The 08's are a little more powerful, more so at the low end.
Old Apr 2, 2009 | 10:14 AM
Red07SSNA's Avatar
Unless you dyno two different cars on the same dyno with the same air temp, the same baro pressure, and the same humidity...dyno numbers are useless...
Old Apr 2, 2009 | 12:59 PM
Staged07SS's Avatar
Administrator
Administrator
the 08's have a bit more advertised torque .... im pretty sure it went from 163 lb-ft to 167 lb-ft in 08'.
Old Apr 2, 2009 | 02:22 PM
warrenb213's Avatar
red07, my point was that they are give or take within 5hp of each other. aka, difference is as unnoticeable as an 06 vs an 07 ls
Old Apr 2, 2009 | 04:00 PM
Kodatech's Avatar
Anyone have a STOCK 2.2 L61 manifold laying around? Post a picture up of the ports with a ruler/tape measure next to the ports and I will do the same for my 2008 2.4 manifold.....we can see if the 08 LE5 manifold is bigger than the 08 L61.
Any Takers? My digital camera is ready...just waiting on a 2.2 owner that has swapped manifolds and has their old one to measure and take pics.
Old Apr 2, 2009 | 04:06 PM
baggelis's Avatar
i have a 2.4 manifold that came off an 08 and before we put it on we measured the runners compared to the ones on my 2.2 manifold now i dont remember the measurements but i remember that the runners on the 08 2.4 mani were bigger compared to my 2.2 mani and dont take my word for it but i think that the only difference between the 06-07 and the 08 2.4 manifolds is the shape
what i do know for sure is that its worth it!
Old Apr 2, 2009 | 04:09 PM
Kodatech's Avatar
So you put a 2008 2.4 manifold on your car?....the 2-piece glued together one? How was it? I just got mine for free but wont be able to install it for a week.
One more thing baggelis...did you need any other parts besides the manifold and brake booster hose? Did all the stuff bolt up correctly?
Old Apr 2, 2009 | 07:22 PM
thisperishedmin's Avatar
pics of a 2.2 manifold removed?
Old Apr 2, 2009 | 07:46 PM
Jn2's Avatar
Jn2
once sec
Old Apr 2, 2009 | 09:34 PM
Kodatech's Avatar
Anyone have something like these pics for a 2.2 L61? I don't because mine is still installed on the car. But here is the manifold from the 2008 Pontiac G6 2.4L LE5. It is different than the manifold on my L61 car.
and the last pic has me wondering about the highlighted area...it appears to be a fixed orifice...do I need to do anything with it?
Anyone with a 2.2 L61 manifold laying around want to give up some pics? Get a tape measure/ruler and lets figure out the differences....or just some good detailed pictures anyway.
Old Apr 2, 2009 | 11:14 PM
baggelis's Avatar
yep this is the same manifold i got or at least it looks like it
Old Apr 2, 2009 | 11:19 PM
Red07SSNA's Avatar
Thanks for posting the pics. The highlighted area is the PCV orifice -- just make sure the seal is in place like it is. The 06/07 2.4 manifold has a plate/gasket assembly that goes there -- the 2.2 manifold PCV orifice is the same as in your "quoted "picture here.
Old Apr 2, 2009 | 11:20 PM
Kodatech's Avatar
PRIMO!! Thanks for the help baggelis. I am going to install it april 11th, so I will give everyone a "seat of the pants" review of how the power and torque feels. Sorry but I have no dyno acess.
Thanks to you to Red07SS
Old Apr 3, 2009 | 04:06 PM
Kodatech's Avatar
Ok but seriously....after all the 2.4 manifold swaps...NOBODY has a 2.2 manifold laying around they could take some clear pictures of??
Old Apr 3, 2009 | 11:09 PM
Kodatech's Avatar
Bump for pictures of 2.2 manifold? Pretty please?
Old Apr 3, 2009 | 11:31 PM
Jn2's Avatar
Jn2
they are around here somehwere, check the how to section
Old Apr 5, 2009 | 08:58 PM
Kodatech's Avatar
I checked, several times actually, but I can't find any good pics with measurements and different angles.
Old Apr 5, 2009 | 09:03 PM
Spanky's Monkey's Avatar
i got an 06 L61 manifold right here is that what you want? pic of course.
Old Apr 5, 2009 | 09:08 PM
07blackg5's Avatar
Slobodan Milošević
i have an '07 2.2 in the garage. if needed i can go grab it. but it looks like ^^^ is about to do it
