200whp N/A?
#301
****, by the time im done im lookin for 300 (but thats a fuuuuullllllllll engine build...and really wont be much of street drivable haha).
I plan on building the block to handle 9k rpm, custom cam, all upgraded valve train, lsj head swap, balance shaft removal, stroked, bored, high compression, etc...for right now i just need something to get me by
#303
"An engine modified with a longer piston stroke (the distance the piston can travel up and down in its cylinder) to produce more power. Often combined with boring (increasing the diameter of the cylinder); the resulting engine is described as stroked and bored"
#304
"Increasing the stroke increases the swept volume of each cylinder and enlarges an engines displacement; decreasing the stroke reduces the swept volume and lessens the engines displacement."
#306
and hell, if it got bored and stroked and made the power a bit lower instead...then id be ok with that :P
#307
good luck bud. your 200 whp marks are 100% attainable. albeit the car will basically be no fun whatsoever to dd. as all your power will be in the top end. not to mention i still don't think you understand what it's going to take to hit that 200 whp mark. the engine will be a beast yes, but ur in to custom parts and deep pocket's territory there.
your 300 whp goal is ridiculous. without a professional race shop at your back and "overnight parts from japan" you'll never get close. by the end of it the engine wouldn't even resemble anything even close to an l61.
#308
If 200hp doesn't happen I'll mail you my stage 3s coming out of my spare head.
#309
Stroke ratio - Wikipedia, the free encyclopedia
http://tinyurl.com/2f2f56u
The honda K-series motors use the same Bore that we have at 86mm but use a shorter stroke at than us. They use 86mm stroke to maintain a "square" engine which is really what you want if you turbo or rev high reliably. With the engine being square it maximizes performance while keeping the piston and rod accelerations lower. Since they are lower at a given rpm vs our engine theirs can rev higher to get to the same piston accelerations we are seeing. Im sure I could do all the math needed to find all the right measurements for our engine but that would take a long time.
Another thing to look at is our motor probably wont make as much power as a K20 or k24/k20 hybrid because their heads flow so much better than ours do. These engines are made for N/A so they will be better. We should be able to get close though if someone were to do a full out build correctly. It needs to be thought out though. If someone with money just starts throwing aftermarket off the shelf parts at a motor they will probably be disappointed that it didnt make as much power as they thought.
#310
then ill revise again to 185-195whp
i dont think anyone is discouraging him from doing it, im just throwing out what my guess is to how much he'll make.
not gonna happen with the current bottom end, as well as the fact that im pretty sure our ecm doesnt go past 8200rpm (atleast the LSJ ecm doesnt)
go to ecotec forum. Maven has an AMAZING post on everything needed to achieve a 10,000rpm redline, factoring in material strength, valve train, etc. He basically says its not going to happen in this community unless theres some serious destroking, but yea, leafy is right. If you want power AND torque, bor and stroke. If you are willing to sacrifice some torque for a decent gain in power, then boring is still fine, but you either want to leave stroke alone, or destroke it to 2.0L.
crank that thing to at LEAST 9000 rmp redline. otherwise your going to fall short. n/a 4 bangers make all their power up top. you just need to make sure you upgrade the valves, springs, and retainers to handle that. if a n/a 1.6L honda can get 200whp, im pretty sure a 2.2 ecotec could.
no...i was correct in what i said haha
#311
We dont need to rev to 10,000 rpm. Like I said before I think 8500 to 9000 max is plenty high for an engine this size.
#315
I wish i could afford your cyl head at this point :P but it would almost be overkill till i build out the bottom end :P
And hell....maybe one of these summers ill have to road trip it down to you seeing as we are on the same coast and all
#320
not all the production stuff is crap, but it could be better if more time and money were put into it. hence the reason its production, make alot of stuff for as cheap as possible in an assembly line or whatever and its not as good as a custom piece (like what i do) is. are u with a company that produces stuff for these cars?
mike
#321
Supporting Vendor
Then looking at the highest HP motors in the world, you won't see 100WHP per liter w/o very high rpm (motorcycle) or very high compression which is above what pump gas will yield. I believe this conversation was telling Matt, not at 10k rpm and we are talking pump gas. No, it's not really possible with those to stipulations.
I find it humorous that people are talking about running the 2.4 intake, TB and things like that. Are you aware that no one is at 200WHP (that I know of) with a 2.4L? That's 10% more displacement, variable cam phasing and higher compression.
#322
Because the physics do not support it.
like I said, im just waiting on the dyno owner to call me back with a sched for throwing my car up there and we shall see what it yeilds
#323
Supporting Vendor
Did you dyno the car stock? Lots of people have done intakes, exhausts, TB's, etc. People aren't making 150WHP. Why would you make 200?
Furthermore, to my knowledge, no one is making that with a 2.4 which has every advantage over you. I'm not trying to be a downer, I just don't see why you'd think some type of magic is going to happen with just your car.
#324
NWAE do you have a pic of your dyno when it was 180? I thought that I remember looking at it in a different thread. Anyway, if you have it why not post it up along with what you had done to the car at the time. Let everyone see what it was as kind of a before, then after the next dyno post up a pic along with the changes. While your build is mild in NA terms, you have done more than 99% of people on this site that I know of, so that way we can see what kind of gains are possible. Whether the gains are good or not so good, we would at least be able to have a general reference point. Good luck by the way, I think you are going to suprise some people.
#325
wow zooomer have you ever heard of a honda f20c? its completely stock with even a paper filter and makes over 100 whp/liter on believe it or not, pump gas! oh yeah and this was back in 1999. yes it does rev to 9000 rpm but makes over 200 whp @ 8k. imagine what it would do with full bolt ons and cams...
