4th cylinder misfire.
Old Apr 13, 2009 | 12:28 AM
redline87's Avatar
geez some ppl are on GM's nuts, if u take can get away w. the dealer fixing it good for u the tech still gets paid for the work u get it under warranty problem solved, ive always felt if u can get away w. it good for u, if they catch u good for them so try your luck....
Old Apr 13, 2009 | 08:03 AM
alleycat58's Avatar
Originally Posted by YzRider452
Amateur racers like us? How the **** do u come off calling me an amateur racer. Why wouldnt i try to get this done on warrenty work.
Because it's not GM's problem to fix?
Originally Posted by Sentry
For some of the shitty repair work they've done on my car, I don't feel bad at all.
Then why the **** would you try and get a MAJOR repair done under warranty. That makes NO sense what so ever. "Yup, they done fucked up my oil change, but hopefully they'll rebuild my motor."
Or.....people who have legit warranty claims are sick of having to deal with the fallout from all the people who try and float bogus warranty claims.
Old Apr 13, 2009 | 08:43 AM
Spanky's Monkey's Avatar
good to see the ol' boys club never fails to show up and set the record straight. it's too bad for the boy racer in us that our **** breaks down after a little rough play. oh, well if we wanted to play street racer shoulda got the ss/sc and we'd have better quality cars we wouldn't have need for claims on. gm's quailty has never failed to let me down and i don't mind seeing those guys pay for it every once in a while.
yeah that made about as much **** as it does to teabag gm cause we all own cobalts....well most of us here anyawy. i hope to hell they fix his car on their dime.
I didn't know america died.........
Old Apr 13, 2009 | 08:59 AM
scott allen's Avatar
You are screwed the same thing happened to me in my old car took it apart and found pieces of the ring no top of the piston.Take it apart and fix im 100% sure thats what happened.Take out that spark plug and shine a light in there and the top of you piston will be ate up by the pieces of rings in there,thats why your plug gap keep closeing on you pieces of rings are hitting it .PeriodIt suck been there done that,**** n20.
Old Apr 13, 2009 | 01:25 PM
BLAZIN07SS's Avatar
I'm too JDM for you
warranty work for techs suck. we hate that ****. repairs paid by the customer is where you make your money, not on warranty work...especially something of that level. EX: if i see a car come in with nitrous installed and it needs a new timing chain tensioner/valve cover gasket, i'm not gonna say **** cause it has nothing to do with the problem. but if i even have the slightest hint that your trying to pull one over on me to get something covered under warranty that you fucked up, you better believe i will be trying to not get it covered under warranty.
Old Apr 13, 2009 | 01:27 PM
Red07SSNA's Avatar
I've heard that the techs get paid less when doing warranty work...Why?
Old Apr 13, 2009 | 01:37 PM
adrian3938's Avatar
And if you wanted to play street racer you should of got a honda or nissan lol , my honda accord lasted til 270k lol
Old Apr 13, 2009 | 01:44 PM
BLAZIN07SS's Avatar
I'm too JDM for you
on flat rate, lets say for an engine swap you get paid for 8.5 hours if the customer is paying for it. on warranty(depending on manufacturer set times) you might get only 5 hours. *these are just example numbers*
Old Apr 13, 2009 | 01:48 PM
hugemurph4's Avatar
**** honda
Old Apr 13, 2009 | 01:50 PM
BLAZIN07SS's Avatar
I'm too JDM for you
Originally Posted by hugemurph4
**** honda
random post is random
Old Apr 13, 2009 | 01:54 PM
  #36
adrian3938's Avatar
lol
Old Apr 13, 2009 | 08:35 PM
  #37
lol..you really took that serious? naw adrian, i know you're a little smarter then that. you read between the lines right.
Old Apr 13, 2009 | 08:48 PM
  #38
YzRider452's Avatar
Well its time to do a compression test. If the cylinder still has compression whats the problem. If it doesnt whats the problem?
Old Apr 13, 2009 | 09:04 PM
  #39
BlueBolt66's Avatar
I understand how you feel seeing how I get paid flate rate as well. But sometimes doing a warranty repair will lead to a happy customer with warranty that will return to have you do something you can make good money on. Even if they only come back for warranty work is better than not returning at all. You think if you void their warranty they're going to come back to an overpriced dealership for work, when they can go to a different shop to get it done cheaper. I'm sure GM is paying all the time that estimating companies such as Mitchell and CCC provides.
Well, you may have thrown a piston bearing. I know of a couple of guys that threw a piston bearing and it gave the piston enough slop to hit the spark plug and close up the gap like you say is happening.
Last edited by BlueBolt66; Apr 13, 2009 at 09:04 PM. Reason: Automerged Doublepost
Old Apr 13, 2009 | 10:39 PM
  #40
laserblue2006's Avatar
now why is gm on the verge of declaring bankcrupt?? o thats right its nice seeing them pay for **** that they shouldnt be have fun with your warranties when they arent there
Old Apr 13, 2009 | 11:33 PM
  #41
b_faulk75's Avatar
Uuummm, actually no, they do NOT pay what the labor time guide calls for, you have 2 labor times, 1 for warranty time and 1 for standard time. We lose on warranty most of the time. It is for this reason that i don't mind seeing gm take it in the ass once in a while since they expect me to everytime i do warranty work. However i still stand behind my original comment, pay to play.
This is not always the reason why the warranty will be voided. If we replace something, especially an engine or major part like that and gm calls the part back to inspect, only to determine the part was damged and not defective, they can charge back the dealer for the repair.
Old Apr 14, 2009 | 11:57 PM
  #42
YzRider452's Avatar
Im opening it up this weekend. Doing all the work with my buddy ballinbalt (jake). Im not exactly sure yet whats wrong with it. But im ordering new piston rings, head gasket, oil pan gasket, and an intake valve and exhaust valve. If its anything more than that ill know this weekend and can order whatever ill need.
Old Apr 15, 2009 | 01:29 AM
  #43
Witt's Avatar
Building it stronger is always the best way to go.
If you have any questions on the build make a thread asking. A few of us have built a "few" ecotecs to say the least and might be able to provide any guidance you might need.
Old Apr 15, 2009 | 10:18 PM
  #44
YzRider452's Avatar
Not building it stronger. My plan now is to fix it completely, sell it and buy an ss sc.
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
jrocstar
Sep 26, 2015 11:42 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
calo247
Sep 8, 2015 12:29 AM
