CA V1 header on 2005 HELP PLEASE!!!!
Old Mar 29, 2008 | 06:07 PM
o3nisoaso3's Avatar
Has anyone tried to install the CA header on their car? I cant get mine to fit because of (what i think is) the thermostat housing/lines that come off it. The flywheel side has an assembly that i cannot get it over. Can anyone help?
Old Mar 29, 2008 | 06:08 PM
SlowBalt_06's Avatar
you should just be able to spin that line abit
Old Mar 29, 2008 | 06:20 PM
o3nisoaso3's Avatar
nope... not that line
heres a pic
THE FLYWHEEL SIDE ARROW IS WHERE IM HAVING PROBLEMS
I HAVE A 2005 WHICH THAT PART IS DIFFERNT FROM 06 AND NEWER
and mine had a lil differnt size part (where the circle is) on the fly side. its like a big connector
Last edited by o3nisoaso3; Mar 29, 2008 at 06:20 PM. Reason: Automerged Doublepost
Old Mar 29, 2008 | 11:14 PM
IonNinja's Avatar
isn't that the reason why there is a CA v2?
Old Mar 29, 2008 | 11:18 PM
joeworkstoohard's Avatar
lmao
Old Mar 29, 2008 | 11:20 PM
cliff883's Avatar
Yes it is, the first model CA made does not fit the 2.2 unless you modify the coolant line or dent in the header where it hits as others have done. But I don't recomend the second method.
Old Mar 29, 2008 | 11:45 PM
pacific cobalt's Avatar
I'd get the V2 if only the collector was not 2.8"
That's for the SC cobalts and not really for a N/A 2.2 cobalt where it would throw your powerband too far up
Old Mar 31, 2008 | 12:07 AM
409Cobalt07's Avatar
i got the v1 and all i had to do is bend the tab on the water pipe on the back and simply grabed it and turned it till it no longer hit the header, i also had to cut off both lower corners in order to get it to fit on my 07. well worth saving the 100 difference between the v1 and v2 imo
Old Mar 31, 2008 | 06:47 AM
Jn2's Avatar
Jn2
hey 409cobalt07 you have some nice mods, u dont see whyu would be running flat 16, i ran a 15.9 on my warm up runs, and got 15.7@best...i only full lsj exhaust, ttr tran mounts, and a cai, you have a header, ad the ss mani, u should be running quicker than that..sorry i know iits off topic, just though it weird
Old Mar 31, 2008 | 04:23 PM
o3nisoaso3's Avatar
i ran a 15.7 stock, from factory
THE 2006 AND NEWER LINES ARE DIFFERENT THAN 2005, THATS WHY IT WONT WORK FOR ME... MAYBE I SHOULD RETURN IT AND GET MY MONEY BACK OR CREDIT FOR OTHER ITEMS?
did you have a problem with that line i have circled?
Last edited by o3nisoaso3; Mar 31, 2008 at 04:23 PM. Reason: Automerged Doublepost
Old Mar 31, 2008 | 04:26 PM
D4u2s0t's Avatar
it very specifically says that it will not fit the 2.2 without modification. why didn't you jsut get the one that fits out of curiousity?
Old Mar 31, 2008 | 06:27 PM
when i did that run it was close to 100 degrees down here in sucktown texas. ive solved my problems tho.... my full nitrous set up with all the extra goodies will be in by the end of this week(crosses fingers)...
yeah i did. i was trying to install it and the more i tightened the header nuts the more it leaked. so i got on line at the shop i work at and did some searching and found 2 options. dent the pipe or rotate it. and i didnt feel like hitting a thin alumium pipe with a hammer so i choose to rotate it. works well and is very responsive in the top end, i love it!
have you seen the price difference? hahaha plus the collector was too big for what i wanted for my balt. the v1 was just what i was looking for and it was the right price too! im not worried about modding things to make them fit, i have a full shop stacked with tools at my disposal. if it takes a little more work to get something to fit... i dont mind taking the extra time to do it.
Last edited by 409Cobalt07; Mar 31, 2008 at 06:27 PM. Reason: Automerged Doublepost
Old Apr 1, 2008 | 03:14 PM
o3nisoaso3's Avatar
i figured the V2 for "header without sai"... well i didnt know if that meant a 2.2 with it that will delete sai so i didnt want to buy it. im gonna try to get the v2 now but my 05 pipe is different than that picture pipe. it has a big thing that bolts onto it right below the last cylinder on the fly side. 05s are different than the others.... ppl need to realize this b4 sayin anything else bout denting **** or fitment
Old Apr 1, 2008 | 03:16 PM
7Thirty's Avatar
Tooooooooo fugging funny
MrInsanityWolf
Sep 29, 2015 04:54 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 28, 2015 12:51 PM
z28addiction
Sep 28, 2015 12:03 AM
