cluster swap...
Old Nov 14, 2007 | 09:04 PM
Jn2's Avatar
Jn2
cluster swap...
well i did it, i mentioned it b4, i did the swap on the cluster, i put the 2.4 cluster on my 2.2 ls cobalt...and, it worked, for more info check out the how-to section, well check it out in a while, cuz i think its still waiting for a mods to approve it, but in the thread i included the steps on swappin them out, everything work fine, nothin went wrong, it all reads good, the needles work good, the dimmer knob works on it fine, everything is GOOD, i repeat GOOD!!!!!!!!!!!!!!!!!!!!!!!!!!!
teaser pic VVV
Old Nov 14, 2007 | 10:01 PM
Red06LS's Avatar
Questions..................
Did your stock cluster to to 120 or 140 (mph)????
If ur stock one only went to 120 how did u correct it?
Thx!
BTW looks nice dude.
Old Nov 14, 2007 | 10:04 PM
HackAbuse's Avatar
So the mileage carried over correctly?
what's up with the temp gauge?
I figured the speed would work correctly
Old Nov 14, 2007 | 10:05 PM
D4u2s0t's Avatar
Thx!
if his stock went to 140, it would be the same one the 2.2 with the sports package has the same speedo as the 2.4
i bet the sensor is unplugged.
Old Nov 14, 2007 | 10:09 PM
Jn2's Avatar
Jn2
yeah the sensor for the temp gauge is unplugged, i m working on moving it somewhere in the intake so that i can get it to read the intake temp instead , also the mileage did csrry over no problem, and i did nothin to correct anything, its simple plug and play, the cluster knows how fast im going, it checked it with the stock in 5th gear around 2k rpm im at 45mph, and when i switch the cluster, it was the same, 45mph in 5th at 2k rpm, no modding, no fabbin, no nothin, just plug and play, when ever the how to get approved u'll see how it was all done, nothin real hard about it, best 40 bucks i've ever spent, way cheaper and better than getting a overlay
Old Nov 15, 2007 | 02:52 AM
Black07LS's Avatar
Is your new cluster from a auto?(all the ones I've seen on ebay are from autos) If so what happens when the shift light should come on?
Old Nov 15, 2007 | 03:20 AM
Red06LS's Avatar
So what exacally comes on a sports package? I have cruse control, wing, etc but i have the 120 speedo and speed limiter is at 105...........
Old Nov 15, 2007 | 04:05 AM
REIGN SS's Avatar
Original Hayden Fanatic
Sport package included aluminum wheels & higher speed rated tires
PS: howto approved
Old Nov 15, 2007 | 04:13 AM
Red06LS's Avatar
PS: howto approved
Ugh.......Not a big deal at all then.....
Old Nov 15, 2007 | 09:09 AM
Sw4y1313's Avatar
Uhm, he said he did it for looks. And i may do this swap as well because that 105 governor isnt going to be a problem for me anymore =P
Old Nov 15, 2007 | 09:14 AM
OrngBalt's Avatar
mr sw4y..... how are we removing the governor?
Old Nov 15, 2007 | 09:20 AM
D4u2s0t's Avatar
i think i remember him explaining it somewhere, i think he needs 2 smt'6's. Something like it only has 2 input and outputs, so he has to get a serparate one to override the speed limiter.
Old Nov 15, 2007 | 09:26 AM
Sw4y1313's Avatar
The SMT-6 has a road speed governor setting, which you run your VSS wire through the Cam sensor 1 in/out on the SMT-6 and then you set the perameters in the Global Settings. Basically theres 2 slide bars. One is for when to activate, and the other i believe is what speed you want the SMT-6 to tell the computer your going. So for example. I'll set the first number to 104mph and the next for say 70mph. So when i hit 104 the car things im going 70 and will allow me to pull past 5k rpms in 4th and all the way in 5th. Now dont quote me on all this exactly. I've been slowly but surely getting my engine back in my car, so hopefully by next week ill be able to confirm all this.
You are correct. I need the 2nd one because im already using the smt-6 for timing. There is this auxilary thing you can attach to the smt-6 which i actually have. Right now its being used as a MAF clamp, but we believe we can use it as well for the road speed governor. If not ill just have to buy another SMT-6. Not very expensive and worth the money to crack the governor.
Old Nov 15, 2007 | 09:34 AM
OrngBalt's Avatar
flib flaber flagoogigly deewoop...
see i can make up things you dont understand too
Old Nov 15, 2007 | 10:00 AM
Sw4y1313's Avatar
If your really interested in knowing how it works your welcome to call me and i can explain it a bit easier. Dont worry ill have a whole thread on the road speed governor once i fix it. I have a 4day weekend coming up next week but my brothers in town. So ill be hangin with him. Hmmm, actually ill have him do some video recording for me so i can actually put out some videos of my car.
Old Nov 15, 2007 | 10:13 AM
madmark's Avatar
teaser pic VVV
i knew it!!! the cluster is just a damn module. it is controlled by the bcm and other sensors
Old Nov 15, 2007 | 10:28 AM
OrngBalt's Avatar
thanks sw4y... i'll be looking forward to that thread... sound interesting and would be quite fulfilling
Old Nov 15, 2007 | 10:57 AM
tonio5555's Avatar
Will this work for me?
I have a 2006 LTZ, I have the upgraded tires and 120mph governor, but my speedo only goes up to 120. I guess they though the white speedo might not look good in my interior. However would be cluster be a direct swap for me?
See here Halfcent was unable to do a swap https://www.cobaltss.net/forums/show...t=cluster+swap
Old Nov 15, 2007 | 10:58 AM
Sw4y1313's Avatar
Your welcome mr orng. Ill show you fulfilling dont worry haha
Hey balmung892003 , sorry for the thread jackage. I love the swap and plan on doing it if i can find the cluster for as cheap as you did. Ill be checking out your How To =P Thanks for your contributions!
Old Nov 15, 2007 | 04:06 PM
Jn2's Avatar
Jn2
i got the cluster for 40 shipped on ebay, and yes it was from a automatic cobalt, itdoesnt matter what tranny the original car had, cuz it swaps over no problem, the shift light is still there<-the auto ddnt need i, but if you loo at a auto cluster, they still have it, just that theyd ont use it...
link to the how-to, has more pics, and proof it works, sorry the pic is fuzzy, i was at driving wen i took the pic,
https://www.cobaltss.net/forums/how-guide-43/how-swap-clusters-84707/
Old Nov 15, 2007 | 06:19 PM
Preston's Avatar
105? wierd...i've had mine going like 115 or 112 before?
Old Nov 15, 2007 | 08:52 PM
Jn2's Avatar
Jn2
yeah mine is governed at 105 also, hmm 112-115 hu? maybe i can go steal the stock tune from GM, hmmm...i wonder if they can just reflash mine to the specs of the sport pakage, since everything is the same engine and sensor wise...hmm, time to call my buddy at GM
Old Nov 15, 2007 | 08:57 PM
Red06LS's Avatar
^^HIGHLY DOUBT IT. No dealer will set you car to go faster, if u died going 115mph then they could be liable because you car is only suposed to go 105.
Try it tho (inetrested).........
Old Nov 15, 2007 | 10:36 PM
07cobaltguy's Avatar
i heard that the sport package had a 120 cutout because of the better tires, since they put shitty ass continentals on the bases.
Old Nov 15, 2007 | 11:10 PM
Jn2's Avatar
Jn2
yeah i have higher speed rating on the tires i have now, but i talked to my buddy at GM, i chatted with him on yahoo, said it wont work, oh well
