Cobalt Parts Interchangeability
Old 05-05-2008, 09:00 AM
  #151
YellowLT's Avatar
Originally Posted by 007CobaltLS
Here's a quick question, are the Ion RL and Cobalt SS/SC exhaust the same? Locally there's a guy that's going aftermarket and I might be able to get my exhaust from him if it's the same.
Most Likely but Take a look at how the piping is routed. or put some pics up if you can.
Old 05-05-2008, 10:23 AM
  #152
blu3_v1p3r's Avatar
yes the ss/sc exhaust bolts up just fine, i put it on my car and it works great, th the downpipe will fit too. Also for the 05/06 cars the header will fit and open it up a little more, for 07 you don't need the header, becasue you already have the same one as the ss/sc stock...
Old 05-05-2008, 10:56 AM
  #153
YellowLT's Avatar
He was asking about a Redline Exhaust
Old 05-05-2008, 09:23 PM
  #154
blu3_v1p3r's Avatar
that what i get for not reading lol
Old 06-29-2008, 11:42 PM
  #155
YzRider452's Avatar
Is there any possible way that an 07 2.2 could use the same cams as an LSJ given they both have a cam position sensor?????
Old 06-29-2008, 11:47 PM
  #156
Blue_Balt's Avatar
I don't think it's possible.
Old 06-30-2008, 12:28 PM
  #157
I'm old school
Halfcent's Avatar
Actually, yes, that could work. But there is a better way to go. Just get the GMPP adjustable cam gear set. Then you could either duplicate the LSJ cam timing, or do any number of other timing options. That's what I did.
Old 07-17-2008, 08:11 PM
  #158
scampbell's Avatar
LSJ Header
Hey guys im not very knowledgeable about the 2.2 motor since i have a 2.0 but i have a quick question for yall. My girlfriend has an lt and this weekend i am thinkin about puttin my springs and my stock header on her car after i take the dremel to it to get rid of some of the roughness. Is this a safe swap and will there be any audible or performance gained or am i wasting my time?
anybody?
Old 07-17-2008, 10:04 PM
  #159
umrdyldo's Avatar
Yes it's a direct fit, just don't break the manifold studs that connect to the Downpipe
Old 07-22-2008, 07:35 AM
  #160
Haz l33t wheelz.
ls1fbody's Avatar
the SS headlights are tinted? WTF? i din't know that.
Old 07-22-2008, 08:11 AM
  #161
YellowLT's Avatar
Put Base Headlights and SSs/c Headlights side by side. The SS's are darker
Old 07-22-2008, 08:15 AM
  #162
Haz l33t wheelz.
ls1fbody's Avatar
no ****. never knew that, or noticed the difference. why did they do it i wonder?
Old 07-22-2008, 08:43 AM
  #163
orde350's Avatar
down pipe does not fit on 08 lt. it will if you add another o2 sensor port before the cat. it came from a 06
Old 07-23-2008, 11:48 PM
  #164
Delta2.2's Avatar
has anyone actually swapped the pistons and rods???????????
i dont wanna buy these unless ive seen it done before. what information backs this up???
Old 07-25-2008, 09:46 AM
  #165
orde350's Avatar
why would you do that? go out and a set of je or something like that. but if you still want to do ss internals just look up bore and stroke of both engines and also crank size.
Old 09-23-2008, 08:24 PM
  #166
ballinbalt07's Avatar
Tires
You may be able to get them to flash the SPORT Package on there, BUT Only do this if you have new Tires. Factory ones shred themselves at 109. That means you dead. This will allow your car to do 120.
Ah Ha!!! But your wrong......lol the stock tires are T rated on the LS that means they are good to sustain a speed of 118mph for at least 10 minutes without tread separation......And as for an LT model with 16" wheels and tires they are H rated which means they can sustain a speed of 130mph for at least 10 minutes straight without tread separation.....The only thing is handling is gonna suck at 118 or so! LOL I know this because I work for goodyear and these are well known speed and handling ratings....FYI
I personally recomend zr rated tires if you plan to shred some pavement..... I know my LT2 handles like its on rails with my Eagle F1 All-Seasons and they're good in the snow.......
Old 09-24-2008, 11:06 AM
  #167
YellowLT's Avatar
My 15" Pos Factory Tires were only s rated so they shred at 112. My bad 3 mph. You also have to remember they changed tires in 07. 05-06 were some continental junk. with the sport package having pirrellis
Old 09-24-2008, 03:22 PM
  #168
blu3_v1p3r's Avatar
I had the continental junk on my 07 LS, but we are way off topic
Old 09-24-2008, 06:42 PM
  #169
Maven's Avatar
You cant swap pistons and rods between different size engines. The reason is because all 3 displacements(2.0, 2.2, and 2.4) each use a different length rod, and piston with a different pin height, also the 2.4 has a large bore than the 2.0/2.2 so the pistons wont even fit in the cylinder.
IE: you cant put LSJ pistons and rods in an L61 You cant put LE5 pistons and rods in an LNF, you cant put L61 rods/piston in an LSJ
In order to mix/match pistons and rods amongst the engine you need to use one stock part and one custom part. for eample if you wanna put LSJ rods in an L61( a reasonable upgrade) youll need to get custom pistons made.
Old 09-25-2008, 11:43 AM
  #170
I'm old school
Halfcent's Avatar
However! In this specific case only, JE Pistons makes those very pistons as a part for GMPP. They are even sold in their catalog.
Old 09-25-2008, 12:27 PM
  #171
Maven's Avatar
Yeah I know, theyve been around for a while, but they are still pretty much a custom part, they are pistons specifically designed with a custom pin height to allow you to upgrade to LSJ rods in an L61. And just like all other ECO reciprocating parts, they wont driectly imnterchange with any other part
Old 09-26-2008, 05:25 PM
  #172
BoffDude's Avatar
i believe the difference is in the cam position sensor. my 07 has an optical cam position sensor. almost sure the LSJ has a hall effect or magnetic cmp.
Old 09-26-2008, 06:11 PM
  #173
hbkingof86's Avatar
So you can put a ss supercharger on a 2006 cobalt LT? If so, i'm interested in knowing if somebody is selling one used for cheap.
Old 09-26-2008, 06:12 PM
  #174
Maven's Avatar
You could swap exhaust cams, but thats it. The intake cam on the 07s has the reluctor wheel for the cam sensor(its not optical, GM hasnt used an optical cam sensor since the LT1's with optispark)
Old 10-02-2008, 05:26 PM
  #175
tru2nrtt777's Avatar
Are you sure bout the bore? Alldata shows them to be the same diameter.
Quick Reply: Cobalt Parts Interchangeability
