Control arm bushing
Just roll with the AC Delco ones (stock). They're like maybe $20ea.
All you need is a lift or jack stands, a good impact, maybe a pry bar, a vice, and an air chisel (or maybe a hammer and chisel, but be careful).
Everyone that says you need a press is just asking for it to take longer. My buddy who is a certified gm tech uses a vice to do it. He can do 2 bushings on one car in 20min. Like including lifting and lowering the car. Its SOOO easy.
This must be a Cobalt issue. I've had Prothane control arm bushing in my Cavalier for going on 4 years now with no issues. This car has been tracked too drag strip, autox, and HPDE.
there is too much range of motion in the cobalt arm
https://www.cobaltss.net/forums/susp...shings-101097/
Over harder bumps you'll hear a slower kind of rattling. Like take the rattle a toasted endlink makes, and slow it down and make it a bit lower and thats the control arm bushing on its way out. Over curbs, sewers, and potholes and such you'll notice it.
Or if you have a hoist, throw it up in the air and grab a pry bar and put it in where the end of the arm goes (under the arm in the slot) and pry up. If the arm hits the frame she's done.
I replaced mine last year with fe5 units (i think they're all the same anyway...) and you NEED a press to put the new ones in. I used moog units, their superior in design compared to the acdelco ones.
DANRICKARD
Oct 1, 2015 12:08 AM
