Cooling
Old Jul 28, 2007 | 09:51 PM
NP05Cobalt's Avatar
Thumbs down Cooling
Is there anything for us to keep the engine a little cooler. i dont know about everyone else in FL but my car is running at like 221* all the time except for like 8in the morning and after 9pm when the sun has been down long enough. The car is not wanting to get up and go right away like usual...eh this sucks
any other time than summer my car runs at 208* maybe 215* some days
Old Jul 28, 2007 | 09:53 PM
06blackg85ss's Avatar
well if you have an ss (either) you can get someone with hp tuners to change how and when the fans come on.. my car rarely goes above 185-190 anymore.,. normal cruising is 180
g5mike's Avatar
Gm has some bi-pass valve that runs the car cooler,don't quote me I cant quite remeber the name of it,and there is also meth injection
Psykostevo's Avatar
Edit your fans to come on immediately in HPTuners, and drill 3 holes in your thermostat (tiny holes)
Old Jul 28, 2007 | 10:03 PM
NP05Cobalt's Avatar
i have a 2.2... cant use HPTuners... i need something for the 2.2 that i can use
Old Jul 28, 2007 | 10:06 PM
g5mike's Avatar
An intake will drop it some,and get you that throttle response back
Old Jul 28, 2007 | 10:12 PM
NP05Cobalt's Avatar
lol i already have the Injen intake...theres nothing for us like the HE or anything huh?
Old Jul 28, 2007 | 10:38 PM
NJHK's Avatar
I don't think it should be that high.
Take it to your dealership.
Old Jul 28, 2007 | 10:57 PM
NP05Cobalt's Avatar
eh im way out of warranty and all local dealers are dicks...maybe ill change my coolant... but theres not a HE for us or anything like that?
Old Jul 28, 2007 | 11:00 PM
NJHK's Avatar
You have a heat exchanger
It's called your radiator lol
I was under the assumption you were under warranty. Can you give anymore details on what is going on with your car?
Old Jul 28, 2007 | 11:02 PM
NP05Cobalt's Avatar
lol i know about the radiator just i figured maybe an "aftermarket" HE... if its the middle of the day and i try to take off it doesn't have the same "umph" as it does when its early morning or atleast an hour after dark... after an hour of dark my temp drops a few degrees...yes its hot in FL but jesus my car is acting up... think changing coolant will help at all? i also hope there is something that i can install to help too
Old Jul 28, 2007 | 11:29 PM
razorhead89's Avatar
My friend died last year from chain letters repost this or she will come and kill you every thime u here a ring in your ear she will make your life shorter and shorter repost this to 2 other video not really but had to repost this sorry
Old Jul 28, 2007 | 11:31 PM
NP05Cobalt's Avatar
why are you spamming here?
Old Jul 28, 2007 | 11:40 PM
halfj99's Avatar
you could try that purple ice stuff from royal purple, you might need a new thermostat too, also you could try to fit an electric fan from a 98-05 N-body (grand am, alero,malibu) fan, it has two fans on it insted of one
Old Jul 29, 2007 | 08:45 AM
YSUsteven's Avatar
You could remove that plastic engine cover, may help by 2 degrees...
Old Jul 29, 2007 | 08:58 AM
TVS_SS's Avatar
sounds like somthing is wrong with your car.
Do the basic stuff, flush out the coolant, replace thermostat, clean out radiator, make sure your fans are kicking on, etc..
if that doesnt work, your water pump may not be working right.
The coolant system is a fairly simple system and there are truly only a few things that could be wrong.
Old Jul 29, 2007 | 09:09 AM
7Thirty's Avatar
Man.. its just been EXTRA ******* HOT this summer... I will check my temps to see where im running and let you know.. im not running a CAI and i dont think im that high so u may have something else going on... but this summer has been extra hot so it may just be the weather
Old Jul 29, 2007 | 02:25 PM
Mr.N00bLaR's Avatar
I think something may be up. It's not as hot up here in NY but my 2.2l (no mods + engine cover) never rises above 202 in the 90 degree days here. The engine is at it's hottest when colder at night I assume because the fans slowdown/turn off.
Old Jul 29, 2007 | 03:38 PM
NP05Cobalt's Avatar
well now that i think about it i am in stop and go traffic all day which yes it does make more sense... but i am still gonna do a coolant flush... if this doesnt help is there a bigger stat i can put in? and how about a bigger cooling fan?
Old Jul 29, 2007 | 04:01 PM
WopOnTour's Avatar
Replace the stock fan assembly with the LSJ twin fan setup
Connect the L-Blu wire from you motor to FAN1 and the Grey wire to FAN2 (and add the grounds of course)
HTH
Wop
Old Jul 29, 2007 | 05:51 PM
WopOnTour's Avatar
Originally Posted by xCobalt05x
was wondering about this. what do you mean "add" the grounds.
im not sure what you mean by that
The 2.2 uses a "dual speed" cooling fan motor that has 3 wires going to it:
LOW SPEED POWER(L-Blu)
HIGH SPEED POWER (Grey)
GROUND (Black)
The 2 LSJ motors are both single speed type (even though they can be series wired for low speed)
Each motor MUST have both Power and ground so on the LSJ fan motors you will need to add the L-Blue and Grey wires AND a connection into the ground (black). So you have to connect the power to each THEN splice a pair of wires to the old ground so you have TWO grounds (one to each motor)
Don't just add your own ground use the original. That way you'll keep the "clamping" diode in the circuit and prevent radio noise when the high speed fan turns off
HTH
Wop
PS> If you find one of these LSJ fan assemblies in a salvage yard make sure you cut the wires to try to take the connectors too. Barring that you can purchase a pair of "pigtailed" fan motor connectors from GM PN# 88988311
Old Jul 29, 2007 | 05:53 PM
Moza13-'s Avatar
you have to be joking me, wow
Old Jul 29, 2007 | 11:05 PM
WopOnTour's Avatar
ok, so what if i hooked both power wires up to the fans. like say i have 2 Lblu and 2 grey wires with a set going to each fan
The L61 fans are programmed as follows:
The ECM commands Low Speed Fans ON under the following conditions:
• Engine coolant temperature (ECT) exceeds approximately 106°C (223°F).
• A/C refrigerant pressure exceeds 1 310 kPa (190 psi).
• After the vehicle is shut off, the ECT at key-off is greater than 140°C (284°F) and system voltage is more than 12 volts. The fans will stay on for approximately 3 minutes.
The ECM commands High Speed Fans ON under the following conditions:
• ECT reaches 110°C (230°F).
• A/C refrigerant pressure exceeds 1 655 kPa (240 psi).
• When certain DTCs set
When the request for fan activation is withdrawn, the fan may not turn OFF until the ignition switch is moved to the OFF position or the vehicle speed exceeds approximately 10 mph. This is to prevent a fan from cycling ON and OFF excessively at idle.
SO
If you wanted to use the LSJ fans to create maximum cooling you would just connect BOTH fans to the L-Blu and then BOTH fans would run at the LOW speed command points.
HTH
Wop
Old Jul 30, 2007 | 02:21 PM
Psykostevo's Avatar
Great! Now you are going to get us all killed. Quit being a dick!
Old Jul 30, 2007 | 02:57 PM
YellowLT's Avatar
Super glue your thermostat open LOL
