Custom Ram Air Question......
Old Sep 26, 2006 | 08:32 PM
Red06LS's Avatar
Question Custom Ram Air Question......
I noticed the air intake that comes from the bottom of our air box when i was putting in my new lights. Aneway i was thinking of re-pluming that so it would get fresh air from the lower grill. First question, would that help? Second question would that increase the rist of me hydrolocking my car??? If its safe and functional i will but i need to know this first... Thanks.
Old Sep 26, 2006 | 10:54 PM
ChrisAult2004's Avatar
I dont think that hydrolocking would be that major of an issue here. i think that you would only have to worry about that if tiy fully submerged ur bumper in water. if you put a short ram intake on ur car and modified the stock airbax to fit it, it would even more greatly decrease the chances. And yes, it would help, rather that pulling the air in that is just floating around in the wheels weel, you would be forcing the air into the pipe, creating a little more power.
Old Sep 26, 2006 | 11:20 PM
iLLmaTic3s's Avatar
a ram air like that should not be a problem..im currently in the process of doing it on my car with the new XTC intake ill be protoypin it with. ill let u guys know..it should hopefully go in this week.
Old Sep 26, 2006 | 11:27 PM
rally's Avatar
Heres what you do, buy the INJEN intake, make it cold air, then cut a hole in the plastic under the bumber...BAM
Old Sep 27, 2006 | 03:09 AM
NJHK's Avatar
It would do very little of difference. I mean, if you want to do it, we aren't stopping you but just saying the gains are going to be little.
Old Sep 27, 2006 | 04:22 AM
Red06LS's Avatar
Its just an ida im throwing out there. Any gain is better than a loss.............!
Old Sep 27, 2006 | 04:46 AM
NJHK's Avatar
True but you have to think about where you're gain is coming from. Think of intake velocity. If you place your filter in that area and extend your tubing, think of how much farther air has to travel and how much longer your air intake velocity has to take to build up. So if you do this and you notice that you gain more power in the higher RPMs, well, you might have lossed a little in the lower RPMs.
So overall, this could be just a waste of time or it could just shift your powerband slightly.
It's up to you overall, just giving my opinion.
Old Sep 27, 2006 | 09:08 AM
iLLmaTic3s's Avatar
it would be nice to tune the powerband..up too bad you cant on a 2.2 l61 engine. yes a ram air is a good idea but mainly its better for higher speeds..getting the air traveling to the cai at a much higher rate forcing the air into the engine. yes at low speeds it may not help..but u still will get some gain from it. my friend has one on his 2.0L and he was pretty much stock with airbox mod and ram air to the airbox mod and keeping up w/ stage II cobalts. a ram air def works.
Old Sep 27, 2006 | 09:20 AM
rally's Avatar
Dont expect much gain at all, I remembered you altered your stock intake, so your still going to be extremely restricted due to the intake design
Old Sep 27, 2006 | 09:27 AM
mkulrey13's Avatar
Ram air does nothing really. Just a waste of $$.
Old Sep 27, 2006 | 09:33 AM
iLLmaTic3s's Avatar
i changed it just for now...im in the process of developing a intake with kenny from Cobalt Addiction for our cars. then possibly doing a ram air. so ur sayin with more forced air into a intake nothing will happen? thats saying if u force more air into a superchager it will do nothing..hmm interesting. well we will see what happens.
Old Sep 27, 2006 | 02:50 PM
daman
Guest
Posts: n/a
unless you can actually make it to where you are actually pushing in more air than the motor can suck in you wont be gainind anything but sound.
Old Sep 27, 2006 | 03:14 PM
06cobaltls's Avatar
so what if i used my sri, the filter is made to run a pipe directly into the center, if i stay short ram, but ran the tube from it to the front of the car into a velocity stack would that be better than putting the filter at the front of the car
Old Sep 27, 2006 | 05:05 PM
NJHK's Avatar
Only one way to find out.
Old Sep 27, 2006 | 05:20 PM
tonio5555's Avatar
Very true. maybe if you removed the front grill and ran some type of tubing from the SRI to the opening you'd see a worthwhile gain, but other than doing that i doubt a ram air would be anything to write home about.
Old Sep 27, 2006 | 11:14 PM
iLLmaTic3s's Avatar
yooo tonio. i dunn bout the ram air..i think its a good idea..im finally getting some time to do my exhaust with probably the XTC HEader. also me and kenny from CA are making XTC intake for our car and the 2.4. should be on this week. ill let you know
Old Sep 28, 2006 | 12:39 AM
Red06LS's Avatar
I took out my headlight today after work to see if i could do the ram air thing but where the snorkel is there is no way to pipe it to the lower grill, its like its in a closed box under the headlight, i would have to do some cutting if i really wanted to do this so i dono yet...........
Old Sep 28, 2006 | 07:38 AM
iLLmaTic3s's Avatar
yep. u have to cut out a part of that "box" to run some piping to the middle of the grille.
Old Sep 28, 2006 | 10:57 AM
CARLYLE's Avatar
im gonna have to pull the bullshit flag on that one. a ram air hardly works. and when it does work oyu have to be doing like 60 mph to even make it functional. and a ram air that might give you 5 horse at the engine is not gonna make you keep up with stage 2s. and you cant even make a real ram air for our cars anyway you can make it blow on one side of your cone filter or the other but thats not real ram air.
Old Sep 28, 2006 | 11:01 AM
CARLYLE's Avatar
thats the way i have it but its not ram air its just giving you fresh air is all. because by the time the air gets there it doesn't really have any velocity left over to force thru the filter.
Old Sep 28, 2006 | 12:18 PM
tonio5555's Avatar
Keep me updated man. Good luck.
Old Oct 2, 2006 | 11:26 PM
223RIMFIRE's Avatar
I saw that gm was coming out with this intake and someone posted something about making it ram air through the hood. Any idea on whether this would be better than going cai. Oh I also have the air injection and the only cai that i know of made for my car is from k&n if that even changes anything(I've just heard everyone boasting that injen is the best for our cars).BTW sorry to hyjack the thread.
Old Oct 2, 2006 | 11:32 PM
NJHK's Avatar
It won't make a difference honestly. The intake will perform the same way either way you do it.
Old Oct 3, 2006 | 10:52 AM
Halfcent's Avatar
I'm old school
The stock air intake is in the right front fender. It is a multi-chamber, ugly ass piece of injection molded plastic. It takes air from behind the right front headlight, routes it through a tube with an air chamber above and a water chamber below, then up to the bottom of the air filter box.
You don't have to cut it. Just remove it as an assembly. Take the right front wheel and wheel well off to gain access. It's held in with just a couple of screws. Then run whatever kind of ram air pipe you want off the bottom of the filter box. If you are going to go to all that trouble however. I would just remove the stock filter box as well and run induction all the way from the throttle to where ever it is you are going to put your filter.
no_ss
Oct 18, 2015 11:58 PM
patooyee
Oct 15, 2015 05:11 PM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
