damper
Old Apr 26, 2006 | 12:48 PM
WadaSty51's Avatar
damper
will the ingalls engine damper fit my 2.2 ls and how hard is it to install?
Old Apr 26, 2006 | 12:50 PM
R33P3R007's Avatar
360 L337 User
Why, is it wet?
I think you meant Dampner, and I don't think it will fit the 2.2
CivicKiller98's Avatar
apparently it isnt for the 2.2, but if you have access to the right tools its definitely doable
Old Apr 26, 2006 | 12:52 PM
R33P3R007's Avatar
360 L337 User
the install of mine last night took maybe 15 minutes, that included install, running to the garage to grab the Right tools, then testing it, and adjusting it.
Old Apr 26, 2006 | 12:56 PM
can you take some pics of your engine bay so we can see the differences between the 2.0 and 2.2? i really dont get the issue that leo at weapon r was telling me about.
Old Apr 26, 2006 | 01:06 PM
R33P3R007's Avatar
360 L337 User
Here are some from ENUFPWR
Originally Posted by ENUFPWR
Got mine and installed in 10 minutes... EASY install.
Took some pictures....
Old Apr 27, 2006 | 02:16 AM
Gus RT's Avatar
i posted in another forum, according to tom at ingalls fits any model
Last edited by JonyyB; Apr 27, 2006 at 10:21 AM. Reason: Only Supporting Vendors can advertise.
Old Apr 27, 2006 | 12:30 PM
WadaSty51's Avatar
what is install....like what do u do
Old Apr 27, 2006 | 02:32 PM
IonNinja's Avatar
i don't think I have that piece that the dampner connects to on the ion 2.2
actually heres a pic to see...not sure if cobalts are the same
edit:
oh wait nevermind, does that plate come with the dampner? looks like it.
Old Apr 27, 2006 | 02:35 PM
R33P3R007's Avatar
360 L337 User
nope, you are missing the piecs of the motor mount
Old Apr 27, 2006 | 02:37 PM
R33P3R007's Avatar
360 L337 User
one side goes to motor mount and one side goes to the frame mpunt. no jacking up or supporting needed.
Just remove 2 outside motormount bolts - install bracket 1
remove frame mount bolts - install bracket 2
install dampner with oring on bracket side, and your done really. I had to adjust mine to about 11.5 from 14 when i got it i was gonna go all the way in to 1o but i get no wheel hop with 11.5
Old Apr 27, 2006 | 08:30 PM
Wyoming_Bass's Avatar
ill be testing the dampner and yes it will fit.
Old Apr 28, 2006 | 01:37 AM
IonNinja's Avatar
what pieces? it looks like that bracket installs on the motor mount and the dampner is then installed onto the bracket...not sure about the part of the dampner that goes down but the other part looks to fit.
Old May 9, 2006 | 08:25 PM
roccityroller's Avatar
someone put this on a 2.2 and take pics because some people are saying yes and some are saying no and we need an answer
Old May 9, 2006 | 08:54 PM
05sedan's Avatar
if u will look at the mount on the engine side ::not where the bracket goes over the mount:: the 3 bolts are closer together on the 2.0 than on the 2.2 that is the only difference...so u might have to redrill the holes and thats it
Old May 9, 2006 | 09:00 PM
Mercury's Avatar
Just as 05sedan said, the mount on the actual motor is different on the 2.0 from the 2.2
It will not fit
Old May 9, 2006 | 11:22 PM
Clmbngfrk18's Avatar
any update on that does it bolt on or slight modding needed
Old May 10, 2006 | 01:31 PM
robstamina's Avatar
Ok guys...
looks like the motor mount measurments MIGHT be the same as the 2.0ss...BUT there is definately an issue with the damper clearing the factory air intake.SOO with that said it could fit but you are going to have clearance issues with the air intake assuming it is the same motor mount as the 2.0ss's...When I looked at an ls it looked like the motor mount was the same(i didn't measure it or try to install the bracket cause it was outside of work at a car meet at night)
So if you have an aftermarket air intake that clears the area of the of where the damper is you MIGHT be able to do it(or modify/cut the factory air intake). AGAIN though I did not measure it or try to install it in relation to the motor mount..I just "eyeballed" it and it looked the same.
If you want to rule out the motor mount fittment someone needs to find out the part number for the 2.0ss motor mount versus the 2.2 motor mount..Ingalls is getting an ls in here in the next couple weeks to actually confirm whether it fits or not. I would maybe recommend waiting until we are 100% on whether or not it fits as opposed to my "eyeballing" the mm at 11 at nite in the dark..
you could PROBABLY mod the bracket and slot it to make it fit but again the air intake clearance is the main concern. I will post up in here as soon as I find out info on it..sorry to add to more of the confusion..currently Ingalls is not listing it cause we are not 100% sure..so for now 2.0cobalt ss...
Old May 10, 2006 | 01:37 PM
BLKSS's Avatar
Im about to order this piece. Denny showed me in person and looks real neat. What do you guys think? Is it worth every penny?
Old May 10, 2006 | 01:44 PM
robstamina's Avatar
and again you are going to have an issue of it clearing the factory air intake.
Old Mar 18, 2007 | 01:48 PM
RollOver360's Avatar
updates?
later
Old Mar 18, 2007 | 03:10 PM
IonNinja's Avatar
what? where have u been? its already been proven to fit a long time ago with an aftermarket intake
Old Mar 18, 2007 | 03:38 PM
Weird, I did a search and only 2 threads came up in the 2.2 Performance section. Thats awsome that it fits, now I can get ride of my nasty wheel hop.
later
Old Mar 18, 2007 | 04:16 PM
RollermanDan's Avatar
The dampener WORKS on a 2.2L...but you MUST have an aftermarket intake. Here's a picture of an installed Ingalls Dampener on my 2.2L Cobalt.
DANRICKARD
Oct 1, 2015 12:08 AM
cw383
Sep 30, 2015 12:41 AM
inhale
Apr 29, 2006 06:48 PM
9JordonFlex9
Mar 20, 2006 01:21 AM
