desided to build my own intake
Old Sep 3, 2006 | 07:09 PM
turbo06ss's Avatar
Old Sep 3, 2006 | 07:10 PM
mkulrey13's Avatar
what did you use. looks legit good job.
Old Sep 3, 2006 | 07:14 PM
turbo06ss's Avatar
just had som 2 1/2" pipe laying around used it. I also went to the ho,me depot and got a fernco fitting. it only coast me about 50 bucks and it does not though a code. we are going to powder coat it in a few weeks after i put the fogger back in it
Old Sep 3, 2006 | 07:16 PM
Beck's Avatar
interesting, how's it sound? wonder what the gains are lol
Old Sep 3, 2006 | 07:28 PM
turbo06ss's Avatar
Sound preaty good and picked it up a bit. It went 13.8 @ 74mph (2.63 60)in the 1000ft. After i put the intake on and leaving at a higer rpm the car went 13.4@ 77mph (2.56 60). It pulls alot harder in second now. I have to get a better air filter though
Old Sep 3, 2006 | 07:31 PM
RaineMan's Avatar
I thought that was 13.8 in the 1/4th when I first read it.... I was like... holy shyte.
Old Sep 3, 2006 | 08:28 PM
g5mike's Avatar
Originally Posted by turbo06ss
Congrats that looks great, You should build them and sell them to members
Old Sep 3, 2006 | 08:32 PM
RaineMan's Avatar
Will fit 2.2 and 2.4's... great idea! Sell 'em for like $100-$150... make some money... could sell 'em for like $75 w/o filter... I bet people would jump on 'em.
Old Sep 3, 2006 | 08:52 PM
turbo06ss's Avatar
Once i get it powder coated and put the fogger it it i may do that. i had to chop up the stock air box to get the mass air flow out . i also need to build a better hold down for it . other then that i like it. what makes me happy it that no codes came on. YET!!!!!!!!
Old Sep 3, 2006 | 09:16 PM
RaineMan's Avatar
i had to chop up the stock air box to get the mass air flow out . i also need to build a better hold down for it.
I wondered how you got the MAF to fit in there so well.
The lack of bracing is also a definate concern on the short-rams.... the Injen dosen't have any bracing either.
Old Sep 4, 2006 | 12:01 AM
iLLmaTic3s's Avatar
nice short ram....ill get pics of my custom cold air intake...all the custom work im seeing is all short ram intakes...my cold air costed me only 100 bucks and im using a k&n e1009 filter and it works AMAZING. ikept the stock look cuz im on a lease so i didnt want to cut much. im makin it into a ram air..but i feel the response so much better in all gears but even at the higher RPMS it sucks alot of air in and def performs amazingly. ill get pics up soon.
Old Sep 4, 2006 | 11:56 AM
WVcobalt's Avatar
i was thinking of doing that also.. but autozone guy said no way with that fuel/air controller?? that hooks onto the stock box?
how'd u get around that?
Old Sep 4, 2006 | 12:04 PM
RallyCobalt's Avatar
I made one..and well..lol..it's not working very well. The lowend torque seems to be gone completely, and it's throwing a code (after like 2 1/2 hours of driving it threw it) and the gas mileage is HORRIBLE lol. Definately gotta figure that out...1/4 tank on a 20mile trip...no thanks, i'll just drive my 70 4bbl nova and get better mileage and MUCH more power lol.
How'd you get the bend in there for the TB? Just a 45 or 90 degree elbow?
Old Sep 4, 2006 | 12:06 PM
I'll tell ya how i mounted my MAF. Put the pipe in a vice, gently apply pressure on the pipe for the vise to grip it...then take a small square block of wood that'll fit inside the pipe, and use i to flatten a spot on the pipe..then cut a rubber gasket for it. 2 self tapping screws and voila! It's mounted and sealed
Old Sep 4, 2006 | 12:07 PM
Destructo26's Avatar
decided is spelt with a c!
Old Sep 4, 2006 | 12:15 PM
WVcobalt's Avatar
wait can some1 explain this to me?
On the intake there is a mointering device... the guy at autozone said you cant
remove it.. it controlls air/gas mixture?
can i remove it?
Old Sep 4, 2006 | 01:22 PM
06cobaltls's Avatar
no your car wont run for crap, it is located inbetween the big plastic that connects to your engine and your airbox you will set the wire that runs to the intake tubing, that is what they are tallking about
Old Sep 4, 2006 | 01:24 PM
WVcobalt's Avatar
yeah... so how does the other's with 2.2 get ram intakes?
Old Sep 4, 2006 | 02:16 PM
turbo06ss's Avatar
All i did was cut it out of the box. If you cut around it then sand a little bit it is a perfict fit for 3 1/2" pipe. Just make sure that you get the flow right and take ot the MAF so that you don't screw it up. It is easy
Old Sep 4, 2006 | 02:31 PM
turbo06ss's Avatar
this is the post i got mine from Air box mod on 2.2! --2.4 compatible (with pics)
Old Sep 5, 2006 | 04:47 AM
IonNinja's Avatar
needs a bigger picture
Old Sep 5, 2006 | 05:23 AM
nomoreavril's Avatar
if you get an aftermarket intake(aem/injen) then you dont have to worry about the hookups right..it comes with everything? so no codes?
Old Sep 5, 2006 | 05:57 AM
NJHK's Avatar
Exactly.
Old Sep 5, 2006 | 07:29 AM
turbo06ss's Avatar
bigger pic maybe
Old Sep 5, 2006 | 07:36 AM
JRANGER's Avatar
dude u so need to make a diy for this. This full intake rocks
