Does anyone have this header?
I was looking around on ebay and found this header and was wondering if anyone has it. What do you guys think of it? Would it be worth buying?
http://cgi.ebay.com/ebaymotors/05-06...Q5fAccessories
You would have much better luck with the Vibrant header/downpipe/high flow cat:
http://www.turbotechracing.com/produ...23&idcategory=
You get what you pay for... Quality is Vibrant...
I would love to have the vibrant setup but I cant afford it. I also dont feel its worth the money for an ls.
Would the pacesetter bolt up to the lsj dp?
Last edited by 2007victoryred; Nov 16, 2009 at 09:57 PM. Reason: Automerged Doublepost
You will need to cut your current downpipe and clamp or weld on the pacesetter downpipe, included in the kit.
hahaha hes right i have pacesetter header stock dp cut and welded and the catback pacesetter which also got welded together due to constant leaks at the dp flange just buy the vibrant i spent around $400 for the header and catback and about 3-4 hours worth of work to get everything properly installed with no leaks and a year later im looking into the vibrant header/dp combo but havnt figured out what catback i want yet....hmmmf so ill actually be out around $1500-$2000 depending on what i decide because i decided to skimp out....do it right the first time it pays off...
