ecotec header
Old 07-26-2005, 03:43 PM
wikkymaster's Avatar
ecotec header
ok i was just wondering if anyone is positive that the cav's ecotec header, like pacesetter will fit our cobalts? i know its for the same engine so it should bolt up fine, just not sure if it fits in the engine bay or anything like that, doesnt matter if it doesnt match up with stock exhaust since that will all be replaced. just dont want to buy the header and not be able to use it
Old 07-29-2005, 05:14 PM
IonNinja's Avatar
thats what I was wondering...ok it bolts to the block but does the downpipe connect to the exhaust and are the flanges the same?
What about the RK Sport header? I heard it robs a little power downlow but maybe that one is a direct bolt on.
Old 07-29-2005, 07:39 PM
im not even worried about the downpipe since new 2.25 inch pipe will be welded straight to the header you know, just worried if the header itself will fit in the engine bay more or less
Old 07-29-2005, 07:43 PM
MacG321's Avatar
sorry to change the subject wikky but i was wondering where you got the black housings for your headlights... they look awsome
Old 07-30-2005, 12:31 AM
Blk05Cobalt's Avatar
he made them, i seen it on here
Old 07-30-2005, 02:10 AM
heh thanks, yea i made them
Old 07-30-2005, 02:38 AM
you dont mind if i copy you and do it to my buddy's do ya?
Old 07-30-2005, 06:28 AM
IonNinja's Avatar
so you're going to have a downpipe and flexpipe custom made? sounds expensive
I'm looking for a direct bolt on myself.
Old 07-30-2005, 10:34 AM
saturnd00d's Avatar
The Pacesetter will fit the ION, however the others will not due to the design of them (ie they will not clear the firewall, whereas the pacesetter will). None of them will bolt-up to your stock exhaust, since they were designed for J-bodies and the j-body exhaust is different than both of our types of cars. Simply put, if your a cobat or ION owner and looking for a header, the pacesetter will work but you have to get custom piping welded after the collector on the header. Hope this helps.
Old 07-30-2005, 01:35 PM
alright thanks thats exactly what i was looking for
goaliemo
09-28-2015 01:37 PM
z28addiction
09-28-2015 12:03 AM
09-26-2015 06:44 PM
hacadacalopolis
09-08-2015 11:42 PM
Quick Reply: ecotec header
