Entire Exhaust Question
Old Jan 2, 2009 | 01:02 AM
eutechnyx's Avatar
Question Entire Exhaust Question
Ok Im thinking of doing an entire exhaust from header to tip,my question is if i get these http://cgi.ebay.com/ebaymotors/05-07...Q5fAccessories http://cgi.ebay.com/ebaymotors/PACES...Q5fAccessories Is that all I will need for the entire exhaust? The DP is included in the header package I believe.If that is all I need how much of a gain should I expect? One more question,will that setup throw a CEL on my 07 cobalt LS? If anyone has any better suggestions as far as full exhaust setup let me know,Im going to start doing small boltons this year and im trying to get the best gains without throwing a CEL if possible,alright thanks guys!
Old Jan 2, 2009 | 01:09 AM
yellowltcoupe22's Avatar
if im not mistaken the factory d/p has to be cut to make that header work cuz it dont come with a d/p, just an extension to be welded to the factory d/p. the cat back is good from what i've heard, sounds good and is stainless. my suggestion on the header and d/p is to get a zzp mid length combo. the zzp has a high flow cat so it will throw a cel but it wont hurt anythin.
Old Jan 2, 2009 | 01:18 AM
glen229's Avatar
youll def get a CEL with a aftermarket downpipe with hi flow cat
i dont care what anybody else tells you YOU will get one
because i know somebodys gonna chime in and say oh no 120000000 miles and no CEL
Old Jan 2, 2009 | 02:24 AM
YzRider452's Avatar
Im not a big fan of the tsudo and pacesetter names. I personally dont like the fart can look of the tsudo. Also if you wanted a nice clean catback you can always go custom.
Old Jan 2, 2009 | 02:26 AM
glen229's Avatar
tsudo doesnt have a fat can at all.. it looks like the hahn etc.. it has a muffler and a tip .. not a fart cannon that you buy at autozone
Old Jan 2, 2009 | 12:46 PM
eutechnyx's Avatar
where can i get a zzp mid length combo?
Old Jan 2, 2009 | 12:47 PM
brickerenator's Avatar
from zzp
Old Jan 2, 2009 | 01:11 PM
eutechnyx's Avatar
ok,so should i get the cat with it or will the tsudo catback still connect without a cat?also should i get the 02 bung and plug?
hers what i threw together
Mid length header and downpipe combo
VIN :
Model:1.5 inch high temp paint
Option 1:Magnaflow cat
Option 2:Mild steel downpipe
Option 3:2.5 inch downpipe, bolt in
Option 4:None selected
Option 5:I'm keeping my stock downpipe
If i run without a cat,how do I program the PCM? or where can i get an 02 simulator?
Old Jan 2, 2009 | 01:20 PM
no offense
do some more reading
ALL of these questions can be answered, and have been answered in previous threads
Old Jan 2, 2009 | 01:27 PM
eutechnyx's Avatar
oh ok,np man i understand I was just postin it here since i already opened a thread.
Old Jan 2, 2009 | 01:36 PM
don't worry about it
live and learn
Old Jan 2, 2009 | 01:54 PM
06_ion2's Avatar
get the stainless cant go wrong.. mines on its way in the mail
Model:1.75 inch 304 stainless
Option 1:w/o cat
Option 2:304 stainless downpipe
Option 3:3" downpipe, 3" bolt in exit
Option 4:Add extra O2 bung for wideband
Old Jan 2, 2009 | 04:45 PM
i may be wrong but i think the op is tryin to get off as cheaply as possible on gettin the stuff so there is a problem with gettin the stainless stuff from zzp. but you're right stainless is the way to go if you can afford it.
Old Jan 2, 2009 | 06:43 PM
eutechnyx's Avatar
Yeah I havent done anything to my car yet so i figured id start somewhere to make the car a little more enjoyable to drive daily.I might get the stainless though,im going to go catless and i read that the hptuners can delete the codes thrown from the cat and i know a guy with hptuners already so thats np.I was just going to do a 2.5 dp and exit for the 2.5 catback system.
Old Jan 2, 2009 | 06:49 PM
hp tuners doesnt support the 2.2 of any year in the cobalt's that i know of. if you have a 07-08 then you can get ls2edit for it or go throu terifica and get a mail order tune. the mail order tune works for 05 up balts.
Old Jan 3, 2009 | 02:25 PM
YzRider452's Avatar
Do the 2.4 mani swap, with an ebay intake, and an lsj downpipe and catback if you are looking for a cheap route for some decent power gains. I ran that set up minus the ebay intake, i have aem, but its all the same crap. That alone put me at 15.5 vs stock which is 16.1-16.3 at chicago altitude levels
Old Jan 3, 2009 | 02:59 PM
Preston's Avatar
tsudo..good exhaust and sounds amazing
ebay intake..same as anything else. hah just not name brand
LSJ DP is probably the best route to..unless your getting a header too
i would avoid the LSJ cat back, because its still gonna be restrictive, just bigger. idk i'd go aftermarket
Old Jan 3, 2009 | 03:03 PM
YzRider452's Avatar
You remember dude, ^^ that set up was working out pretty nice for me at the track.
Old Jan 3, 2009 | 03:13 PM
Sarbae's Avatar
you might want to make sure you don't have SAI before you get a new header.
https://www.cobaltss.net/forums/show...&highlight=sai
Old Jan 3, 2009 | 06:26 PM
JL-KA's Avatar
He has an 07
Old Jan 3, 2009 | 08:00 PM
eutechnyx's Avatar
Yeah I was planning on doing a header,dp,exhaust.where can I get the 2.4 mani swap? what all would I need to do the swap?
Old Jan 3, 2009 | 08:05 PM
CED is the only place that has the 2.4 mani conversion kit. it has everythin you need to do it with.
Old Jan 3, 2009 | 08:17 PM
eutechnyx's Avatar
ok that looks good,is that gonna be better than buying a header for mine? will the DP/exhaust i was wanting to get work with this mani?
so Im deciding doing the 2.4 mani swap with zzp stainless DP w/o cat,with bolt in 2.5" catback with gaskets,and the tsudo 2.5" catback.do i get the 02 bung installed on the DP or no?
Old Jan 3, 2009 | 08:27 PM
you will get a decent gain from the 2.4 mani but you'll get better results gettin a header and d/p and cat back to go with it. i dont mean you gotta do it all at one time, but doin them all yields a greater result in the end. and yes you can use the mani with the exhaust. once you get it all done then order tune to get a lil more out of it.
the extra o2 bung is for a wide band or egt gauge. if you have no plans on gettin either one then you wont need the extra o2 bung
Last edited by yellowltcoupe22; Jan 3, 2009 at 08:27 PM. Reason: Automerged Doublepost
Old Jan 3, 2009 | 08:29 PM
eutechnyx's Avatar
Ok that sounds good.If I have to take it in to do warranty work will they know its a diff mani? and will they void my warranty? I might wait to do the actual mani till the warranty is gone.I could get everything but the mani and run with that for awhile and then buy the mani and bolt it right up right? one last ? will 2.5" header/dp and exhaust be fine?
