Gauge Cluster Question
Old Oct 18, 2007 | 10:50 PM
BlackLS's Avatar
I have an 06 LS and it has the black 120mph speedometer in it and I was wondering if anyone knew weather or not i could just switch it out with a white 140mph cluster out of a car with the sports package? Like will the speedometer work right and will the odometer read what is actually on my car or will it still be at the mileage from the car it came out of?
Old Oct 18, 2007 | 11:52 PM
DebadgedBALT77's Avatar
if you swap the entire cluster, no, the mileage would not shop up. and thats a BIG no-no . you have to download info off the computer at the dealership. I did this to a colorado the other day. I believe that the ar will store the mileage tho and you have some elaborate way to make it show back up. but ill check for you when i go to work tommorow.
Old Oct 19, 2007 | 12:53 AM
NightRyder07's Avatar
I was also looking into this and it's not worth the cost to do it b/c ur ecu is programmed for a 120 speedo... so u'd have to reprogram ur ecu and do a bunch of other things.... Overall it's just not worth it
Old Oct 19, 2007 | 01:33 AM
avenger09123's Avatar
Not entirely true, none of the mileage data is stored in the digital gauges themselves, you only have to make sure it has the same specs (lcd size, layout, connections, etc) for the lcd to display it's information. The mileage is stored somewhere else, I know this because I crashed an old motorcycle long ago and the new digital speedo showed the same mileage as the old digital speedo, even after D/C the battery, so it stored somewhere else for pretty much anything digitally controlled. Only the old ones now with the wheels that turn for mileage have that restriction where you have to keep the gauge cluster together. Short of shorting out that part of the pcm, ecm, bcm, i don't know any other way to alter a digital readout's mileage.
But I agree the trouble for recalibration isn't worth it to me at least.
Old Oct 19, 2007 | 05:40 AM
Black07LS's Avatar
better way
http://whitegauges.net/whitegauges_r...&productsID=25
Old Oct 19, 2007 | 06:00 AM
REIGN SS's Avatar
Original Hayden Fanatic
http://www.blackkatkustoms.com/
Old Oct 19, 2007 | 07:23 AM
BlackLS's Avatar
I was just wondering cause I saw one for sale cheap online and I thought it would be cool. Also I was thinking that maybe if I had to get them to recalibrate the speedometer I might be able to have them get rid of the dumb 105 speed limiter.
Old Oct 19, 2007 | 03:01 PM
Black07LS's Avatar
REIGN I think you mean http://blackcatcustom.com
Old Oct 19, 2007 | 08:03 PM
Novajoe's Avatar
when I swapped an srt-4 guage cluster into my old neon it kept the mileage from the srt-4 I pulled it out of. My neon was at around 30000 and when I put the srt cluster in the mileage read 14000.
Although I think the mileage in these cars is stored in the bcm. Or possibly the pcm. I'm not sure which.
Also when I swapped my stock 120 mph cluster out for the 160 the srt has, the speedo worked just fine. Lost no accuracy. I didn't reflash anything.
Old Oct 19, 2007 | 08:44 PM
YSUsteven's Avatar
That "dumb 105 speed limiter" is there so that you can't kill yourself or someone else by driving faster than the tires have been designed for and you get a blowout.
If you get higher speed rated tires and if you have a good dealership in your area, they can raise you limiter to reflect your new high speed tires.
Its also there so that we can't bring a lawsuit against GM for making our cars go too fast.
Old Oct 21, 2007 | 08:10 PM
BlackLS's Avatar
Well if you look at my sig it says I have aftermarket rims and tires so thats not a problem.
Old Oct 21, 2007 | 08:12 PM
joeworkstoohard's Avatar
as far as i know, if you swap the clusters, it will just work.
from what i have been told, the PCM sends out the speed to the cluster along with all the other info... so if you put any cluster into any cobalt, the speed/fuel/tach/mileage would be the same.
or, so i have been told.
Old Oct 21, 2007 | 08:32 PM
YSUsteven's Avatar
Then as I said, go to your dealer and have them raise you limiter to reflect your new tires. I don't think you car will ever be able to go 168 MPH.
Old Oct 21, 2007 | 08:59 PM
Novajoe's Avatar
most dealers won't touch those kinds of things whether you have the tires for it or not. It's not just the tires. It's the suspension and aerodynamics of the car as well.
Not to say we can't go faster than 105, but most dealerships don't want to deal with any legal issues.
Old Oct 22, 2007 | 06:42 PM
YSUsteven's Avatar
Um......
Any balt with the "Sport" package has upgraded tires and are regulated to like 125 MPH, or maybe it just can't go any faster than that. They have the same body, and suspension. The only difference is that they have H (130 MPH) speed rated tires instead of the other continental S (112 MPH) rated tires.
Only one way to find out if your dealership would be wiling to do it... Ask
Old Oct 22, 2007 | 07:05 PM
Novajoe's Avatar
Um......
there's no american 2.2 that can go faster than 105 stock because of the limiter. No matter what tires it has
Old Oct 22, 2007 | 07:35 PM
steiny69er's Avatar
my 2.2 goes faster then 105 with stock cont's on 15 inch steelies.
Old Oct 22, 2007 | 07:40 PM
anthonyS88's Avatar
i bet if it could, it would take like 1,000 years for the 2.2 to get to 150 lol
Old Oct 22, 2007 | 07:54 PM
YSUsteven's Avatar
You need to read a little more
Take notice of the 3rd post in this thread
https://www.cobaltss.net/forums/show...light=governer
And you might want to also read this one.
And this one
And this one by Hackabuse, knows what he is talking about.
I could understand if it was just one or two people, but its dozens, get with the program.
Might be able to get there with a 125 shot of nitrus, if it doesn't blow, or run out.
Old Oct 22, 2007 | 08:35 PM
Spanky's Monkey's Avatar
dude your a douche. i've done 125mph a couple of times already. try using the search button and do some reading before you spit such filth.
Old Oct 30, 2007 | 11:27 AM
06CobaltSSSedan's Avatar
Can Be Done!
Just an FYI for everyone on the 140MPH Gauges... My Girlfriend has a 07 2LT Cobalt and it had the 120 MPH Black speedometer and she hated it. I went on ebay and purchased the 140MPH White "Sport" gauges and replaced the entire cluster... A complete "swap"... Take out the Black cluster and put the "sport" cluster in and everything worked perfectly! Mileage stayed the same at 1776, and the computer knows when the "sport" gauge cluster is installed because the speedometer is dead on. (Tested it with a local police officer and a speed gun). A very nice $50 upgrade!! IT CAN BE DONE! All features and setting is DIC work too!
Old Oct 30, 2007 | 02:43 PM
409Cobalt07's Avatar
my car cuts out at 112 which is redline in 4th. i have a base model 2.2 5 spd 07.
Old Oct 30, 2007 | 06:55 PM
YSUsteven's Avatar
Your car has the lower governer because your car came with the crappy tires.
Old Oct 30, 2007 | 09:18 PM
IonNinja's Avatar
hmm, so I've got to find an Ion 3 gauge cluster that is not a 2.4.
Unless someone car confirm that a 2.4 cluster will work just fine...
Old Oct 31, 2007 | 11:28 PM
BlackLS's Avatar
Cool Thank You very much that is exactly what I wanted to know
