Glowbalt's SC BUILD THREAD
Old Aug 1, 2010 | 09:33 AM
Glowbalt's Avatar
Well guys I finally kicked it off with my first big purchase so it's official. any tips/links would be greatly appreciated.
THE BEAUTY that this is going into
RED = PARTS ACQUIRED
-M62 Supercharger
-2.8” Pulley
-LSJ Throttle Body
-LSJ Intake Manifold
-Stage 2 Belt (One rib cut off)
-60LB Siemens Injectors w/ harness
-Intake Manifold-SC Gasket
-TB-SC Gasket
-TB Hard Vac Hose
-Auto Meter Boost/Vac Gauge
-SS/SC INTAKE
-H/E Pump Bracket
-LSJ Lower Intake Manifold Brace
-OTTP Heat Exchanger
-LSJ Belt Tensioner
-LSJ Idler Pulley
-LSJ Alternator Bracket (PN 12584365)
-LSJ Washer Reservoir (PN 22729469)
-LSJ 1 Bar MAP Sensor
-LSJ Brake Booster Hose
-ZZP A-Pillar Gauge Pod (2 Pods)
-Extra Coolant for Engine (1 Gal Prestone 50/50 Dexcool, 1 Bottle of Water Wetter)
-Coolant for H/E Circuit (1 Gal Prestone 50/50 Dexcool)
-H/E Coolant Reservoir
-LSJ Upper Radiator Hose (PN 15247280)
-12' of ¾” Heater Hose
-Intake Manifold-Head Gasket
-H/E Bracket Insulator (PN 12594387)
-H/E Pump Connector
-LSJ Throttle Body Connector (8-Pin)
-By-pass Elbow Hose (Used ¼” Vacuum Hose)
-Vac hose for Valve cover to air intake
-Trifecta Tune
-Multiple 90° Bends for ¾” Heater Hose (Use as needed)
-Multiple Straight extensions for ¾” Heater Hose (Use as needed)
-Washer Hose + “butt connectors”
-Innovate LC1 Wideband Kit (with DB-series Gauge)
-Pulley Boys Tensioner Tool
-Hose Clamps
My list of bolts (courtesy of Gene):
• GM Bolts Needed
- 11516342 – LSJ Intake Manifold Mount To Block Bolts -(M8 X 1.25 x 60) (Qty 2)
- 11589214 – LSJ Supercharger to Intake Manifold Bolts (4)
- 11900248 – LSJ TB To SC Bolts (4)• Standard Bolts Needed (Not GM)
- LSJ 1 Bar MAP To Intake Manifold M6 x 1.0 x 25 (Qty 1)
- LSJ Intake Manifold Mount Bracket To Intake Manifold M10 X 1.50 x 50 (Qty 1)
- LSJ Rear IC Pump Bracket To Intake Manifold Mount M8 X 1.25 X 25 –
- LSJ Front IC Pump Bracket To Rear IC Pump Bracket M8 X 1.25 X 35 – (Qty 2)(Part #12586367)
- LSJ Idler Pulley To Block M10 X 1.50 x 75 (Qty 1)
- LSJ Idler Pulley To Alternator Bracket M8 x 1.25 X 25 (Qty 1)- LSJ Intake Manifold To Block M6 x 1.0 X 75 (Qty 2)
- LSJ Alternator Bracket To Block M8 X 1.25 X 130 (Qty 3)
- LSJ SC Bypass Valve To SC M8 X 1.25 X 20 (Qty 2)- LSJ Lower Tensioner To Bracket M8 x 1.25 x 35
- LSJ Upper Tensioner To Bracket M8 X 1.25 x 40… not standard bolt though. Has to be metric hex socket bolt.
- LSJ Intake Manifold Bolts M6 X 1.00 x 25 (Qty 4)
Old Aug 1, 2010 | 09:58 AM
EatonTVS07's Avatar
Looks like you got it down, good luck with the build!!
Oh, and the hell is with your sig?
Old Aug 1, 2010 | 10:00 AM
Glowbalt's Avatar
I mean links as in good prices for parts..------------and the sig? yea it happens..lol
Old Aug 1, 2010 | 10:07 AM
Axelthered05's Avatar
here are the gm part numbers for the bump brackets and insulator
Intercooler Pump Mounting Bracket Front (Part #12586367)
Intercooler Pump Mounting Bracket Rear (Part #12585150)
Intercooler Pump Insulator (Part #12594387)
just thought it would be handy to have
Old Aug 1, 2010 | 04:22 PM
Glowbalt's Avatar
Thanks!
Looking for parts
Old Aug 2, 2010 | 08:50 AM
Glowbalt's Avatar
Updated: I have some bolts but not sure exactly which ones they are..
bump for update
t t t...really wanna get this done...all I really need are the little things..LOW PRICES PLEASE
Updated
Old Aug 2, 2010 | 01:16 PM
stenguyen1's Avatar
good luck with your build man.
Old Aug 2, 2010 | 01:21 PM
Glowbalt's Avatar
thanks
Old Aug 2, 2010 | 11:06 PM
Glowbalt's Avatar
updated
How much WHP do you guys think I could pull off? I also have a 2.25" Catback exhaust
Old Aug 2, 2010 | 11:10 PM
Marca34's Avatar
I have a M62 with a smoothflow 5 bolt 2.8 pulley and a 2.7. Its blue.
-M62 Supercharger
-2.8” Pulley
-LSJ Throttle Body
-TB-SC Gasket
-TB Hard Vac Hose
-SS/SC INTAKE
-H/E Pump Bracket
-Extra 2.2L Injector Harness
-LSJ Belt Tensioner
-LSJ Idler Pulley
-Bolts
-H/E Pump Connector
-Vac hose for Valve cover to air intake (Cannot remember size)
-Trifecta Tune
-Hose Clamps
• GM Bolts Needed
Old Aug 2, 2010 | 11:13 PM
Glowbalt's Avatar
I have a M62 W/2.8 Pulley on the way..haha
Old Aug 2, 2010 | 11:15 PM
EcoTecDriver's Avatar
Check your stock throttle harness you may need a 8pin aswell if yours is a 6pin.
Marca34's Avatar
Damn. Lol alright. GL with the build. Youll have a nice 4 door sleeper.
Old Aug 2, 2010 | 11:17 PM
Glowbalt's Avatar
Yea that's in the list...thanks anyways
Old Aug 2, 2010 | 11:46 PM
here is somthing for you if you have the 6 pin http://cgi.ebay.com/ebaymotors/6-Pin...Q5fAccessories
Old Aug 8, 2010 | 07:04 AM
Glowbalt's Avatar
updated
some parts
Old Aug 9, 2010 | 12:48 AM
CobaltLs505's Avatar
Good luck wit ur build
Old Aug 9, 2010 | 08:09 AM
noticed you dident have thies items yet here are the part numbers if ya need to buy them
Intake Manifold Bottom Mount (Part #12586632 )
Stage 2 Belt (Part#12597993)
Intake Manifold Gasket (Part #12597855)
LSJ Washer Reservoir http://cgi.ebay.com/ebaymotors/2005-...Q5fAccessories
Old Aug 9, 2010 | 08:30 AM
Glowbalt's Avatar
I do have all those items listed..lol..thanks anways
Old Aug 9, 2010 | 09:08 AM
yes their listed I ment their not in red so i asume you dident have/purchase them yet, I was trying to give you the part numbers since they werent listed with the parts, just in case you needed to buy them new. you misunderstood my post :P
Old Aug 13, 2010 | 05:45 PM
Glowbalt's Avatar
bump. Do you guys think I'll need to upgrade my rods with this setup?
Old Aug 14, 2010 | 10:10 AM
um... 2.8 pully would be dangeriously pushing it, I think it would be safest to eather replace the rods and pistons or get a larger pully like the stock 3.35" I think its like +1 PSI of boost for every .10" down from the stock pully
Old Aug 14, 2010 | 01:24 PM
Glowbalt's Avatar
would stock SS/SC rods suffice?
Old Aug 14, 2010 | 01:34 PM
07SuperchargedSS's Avatar
I dont see why not. They can handle 18lbs of boost, thats how much I was pushing with a 2.8....
actually about 19.5lbs on a good day
Last edited by 07SuperchargedSS; Aug 14, 2010 at 01:34 PM. Reason: Automerged Doublepost
Old Aug 17, 2010 | 08:34 PM
Glowbalt's Avatar
still waiting for parts to be delivered
