GoofyBalt's Supercharged Build
Old Aug 14, 2012 | 07:11 PM
GoofyBalt's Avatar
I bought a kit off of Mongorat, it came in today,
Parts ordered 8/16 thanks to Gene Culley's build thread
GM PARTS #
12575463-LSJ TB Gasket
11900248-LSJ TB to SC Bolts (4)
12584342-LSJ S/C Gasket
12594387-LSJ IC pump insulator
12597855-LSJ Intake mani gasket
12597993-Stage 2 Belt
15247280-LSJ Upper rad hose
15253932-LSJ Brake booster hose
12584369-LSJ TB to Purge Sol Hose
11516342-LSJ Intake manifold mount to block bolts(2)
11589214-LSJ Supercharger Intake to manifold bolts (4)
12345982-GM Supercharger Oil (2)
Total came to $228 shipped
PARTS I HAVE:
m62 Eaton
2.8 intense pulley
60# Siemens Injectors
LSJ Tensioner
LSJ other pulley
Coolant Motor
Coolant motor bracket
ZZP Heat Exchanger
Throttle body
Intake manifold
Ebay Header
ZZP 2.5 catted dp
2.25 Tsudo Catback
If you can point out what im missing, or name anything in the pic that would be awesome haha. First Balt build ever.
Thanks peeps!
Old Aug 14, 2012 | 07:14 PM
Twoozofjuice's Avatar
intake manifold, throttle body, intake, map sensors i think?
Old Aug 14, 2012 | 07:16 PM
GoofyBalt's Avatar
Yea i have that forgot to list it haha, i finally got the picture to work.
Old Aug 14, 2012 | 07:45 PM
08baltls's Avatar
Are you running that on stock internals?
Old Aug 14, 2012 | 07:55 PM
noorj's Avatar
If you plan on running anything under a 3.0 I would highly suggest dual pass, option b and a phenolic intake manifold spacer
Old Aug 14, 2012 | 07:57 PM
GoofyBalt's Avatar
yes i will absolutely run a 2.8 on a stock motor, if i blow it up oh well What will this put me at, around 14psi?
Old Aug 14, 2012 | 08:06 PM
08baltls's Avatar
Well a 2.9 with supporting mods will net around the upper 250hp range. 2.8 should net around mid 260s. As far as psi on that pulley, I'm on a 3.1 and running right around 10psi.
Old Aug 14, 2012 | 08:40 PM
GoofyBalt's Avatar
I have a question are the 2.2l in cavys stronger? I have a friend thats turbo on 20lbs stock motor for 3 years and is fine its a 3076 are these motors really this weak
Old Aug 14, 2012 | 08:45 PM
08baltls's Avatar
I don't know about cavy ecos being any stronger or not. I do know that our factory rods are only rated at like 256hp. But a lot of people run 2.9s with minimal problems so take that for what it's worth.
Old Aug 14, 2012 | 08:50 PM
GoofyBalt's Avatar
Well i guess ill be the guinea pig haha
Old Aug 15, 2012 | 12:49 AM
bluebalt07's Avatar
I'm on a 2.8 and I see between 14 and 15 psi right now in summer weather. I'm sure it will go up when it gets cooler like in fall and winter. Either way I wouldn't run it on stock internals. I ran a 3.0 on stock internals so you might be ok, you might not. You should definitely get all the cooling mods that noor suggested at very least.
Old Aug 15, 2012 | 08:09 AM
GoofyBalt's Avatar
Yea ill pick up the option B/Dual Pass. I probably stick with the 2.8 pulley though.
Old Aug 15, 2012 | 08:23 AM
?! im on a 2.7 (LSJ) methanol etc and putting down 265. I dont think a 2.2 will see numbers that high
Old Aug 15, 2012 | 08:27 AM
went to log this morning and I was seeing 12 psi then would spike to 15 psi >.< I'm supposed to be at 8 lol 3.1 pulley. think my cat clogged or something
Old Aug 15, 2012 | 08:52 AM
GoofyBalt's Avatar
I just bought a Tsudo Catback, ZZP 2.5 catted Downpipe and a Ebay Header. When i get paid again ill pick up the extra coolant tank, LSJ Washer tank, Option B, and Dual Pass, stage 2 belt, LSJ Cai. With these parts and what I have in my top post, am I good to go?
Old Aug 15, 2012 | 08:54 AM
GoofyBalt's Avatar
Ok so I will probably be fine then, Ill just make sure i get it tuned extremely well. There is actually a dyno about 5 mins from me.
Old Aug 15, 2012 | 09:07 AM
def a dyno tune.
Old Aug 15, 2012 | 09:12 AM
GoofyBalt's Avatar
def a dyno tune.
Yea, I was aiming for 250whp myself but would be fine with around 240. I just didnt think a 3.0 pulley would get me there. The guy a Easy Street Rides N Rods, the dyno, is supposedly really good. I just called them and he told me he had expierence with cobalts. Hopefully this all goes well
Old Aug 15, 2012 | 11:52 AM
08baltls's Avatar
I've first hand seen a IRL on a 2.9 with header back exhaust, 42s, and a tune make 258 at the wheels. It's doable.
Old Aug 15, 2012 | 12:13 PM
GoofyBalt's Avatar
This was a 2.2L?
Old Aug 15, 2012 | 12:24 PM
IonNinja's Avatar
IRL = Ion Redline
And there are plenty of guys hitting 250/260whp with bolt ons and a 2.9/2.8. Check the dyno thread...
Old Aug 15, 2012 | 12:26 PM
GoofyBalt's Avatar
Originally Posted by IonNinja
IRL = Ion Redline
Haha my bad i didnt know thats what IRL meant. Yea ive been browsing through the threads checking out peoples builds. I really thought IRL meant In real life lmao!
Old Aug 15, 2012 | 12:29 PM
08baltls's Avatar
IRL is a 2.0 LSJ motor. It's pretty close to a 2.2 in the block but that's where the similarities end.
But for you in a 2.2 with a 2.8 pulley, all the cooling mods, supporting performance mods, and a good supporting dyno tune, you should be in the upper 250 mark.
Old Aug 15, 2012 | 01:11 PM
GoofyBalt's Avatar
That would be fine with me! Its a DD, so i dont need it to get me in trouble haha, i have my weekend car for that. I just tired of it having zero ass to it. 145 BHP gets boring extremely fast. Sometimes i feel unsafe trying to merge on the highway haha!
Old Aug 15, 2012 | 02:46 PM
klotzy_550's Avatar
I see around 11psi with the 3.06 pulley and I believe 8psi was with the stock pulley acoording to ZZP. Btw if thats the case I think its time to but that kitten out and either free flow or install a high flow cat.
