Got My Interceptor and have couple questions
well i got my interceptor and i have a couple questions.
first i didnt connect the three wire plug in the interceptor. it said it was optional.
second my gauge isnt reading a lot of the stuff. i just installed it. maybe it needs to sit and get used to it first.
can someone with the interceptor for the 2.2 help me out. and if possible list what you selected (parameters)
thanks
thanks
it took me like 10 min. i pulld the pillar off. got my ss/sc one that i had here, put the gauge in. centered it and made it straight, hook up the wire to the gauge, connect the end to the OBDII port and i was done.
PULL OF YOUR PILLAR THEN, THEN I RAN THE COMP LINK INTO MY OBD2 PORT AND GAVE IT POWER FROM MY FUSE BOX DO A SEARCH THOUGH I DON'T REMEMBER WHAT I TAPPED INTO, BUT YOU NEED A CONSTANT POWER SOURCE LIKE YOUR SUNROOF FUSE OR MAYBE INGNITION. SORRY BUT DONT HAVE EVERYTHING IN FRONT OF ME PM ME IF YOU NEED MORE HELP I'M SURE SOMEONE HAS A HOW TO DO A SEARCH.
it says that the wire from teh red white and green is optional. it gets power and ground from the OBDII
heres some pics after teh install
DUDE THATS HOT!.. like using the sc pilar. but putting that in it! wow!
