Header for 2.2
Old Mar 21, 2007 | 12:01 AM
Rush's Avatar
Header for 2.2
I am in the market to getting a header for my 2.2 and I was wondering is there any big difference between the brands? I see some listed for $400 and others less than $200. I would rather spend the least possible, but at the same time I want something that is quality, so if I need to spend the $400 then so be it. It just seems to me (not a car expert) that there couldn't be TOO much of a difference in them. Thanks for any helping regarding this.
Old Mar 21, 2007 | 12:17 AM
lil_kano's Avatar
Not to rob your thread or anything but I need some info too because im currently running nitrous and I am looking for some performance headers but I can't find any and CA's has fitment issues on my car's year n model. The Official header thread is pretty good but doesn't give too much info on the fitment side.
Old Mar 21, 2007 | 06:23 AM
06Pursuit's Avatar
pacesetter is awsome. ive had nothing but good come from my set up
Old Mar 21, 2007 | 07:25 AM
07cobaltowner's Avatar
just bought pacesetter, ill keep you informed after the install.
Old Mar 21, 2007 | 11:12 AM
Halfcent's Avatar
I'm old school
There are a few things to consider. First, do you have SAI? Click here. Next, do you want a shorty header that will fit your stock downpipe, or a long tube header that will require a custom pipe? Pacesetter is a long tube style and will require a shop to weld up a pipe for you.
Old Mar 21, 2007 | 11:21 AM
XM15's Avatar
^^ + 1 Do you want to buy a header that is a little more expensive but that will also bolt right up or do you want to go with a cheaper one that will cost more for labor?
Old Mar 21, 2007 | 11:27 AM
djblass's Avatar
the question is wat is better for performance a short header that will fit the stock downpipe or long tube header that will require custom pipe ?
Old Mar 21, 2007 | 11:29 AM
Halfcent's Avatar
I'm old school
The long tube header. It has the least restrictive flow.
Old Mar 21, 2007 | 01:36 PM
TurboTechRacing's Avatar
Pacesetter ceramic coated, we have a very good price on them right now. Check out www.TurboTechRacing.com They are in stock and ready to ship
Old Mar 21, 2007 | 03:08 PM
laserelectric's Avatar
I don't know dude...I found a GMPP one? I think you are able to order it from your local Chevy dealer. I usually try to stick with factory parts. After market tends to have higher performance numbers, but factory parts are usually better quality...IMO.
Old Mar 21, 2007 | 03:42 PM
THE GMPP is just a stock exhuast manifold that is honed out, IMO it is not the greatest thing to do. You will see a power increase, however nothing like you will see with the full tube header.
Old Mar 21, 2007 | 05:17 PM
Ok, see, I wasn't too sure. At least it isn't plastic!? LOL!
Old Mar 21, 2007 | 10:50 PM
Rush's Avatar
Isn't there a header I can get with a downpipe already? And would this hook to a stock exhaust, or would I need to get an exhaust also? I am pretty uninformed when it comes to these things, but am I right when I say the header connects to the downpipe which connects to the exhaust?
Old Mar 21, 2007 | 11:07 PM
lil_kano's Avatar
Ok my question is what is the best shorty header, performance wise, because i will not leave the downpipe stock so it wont be restrictive. I dont want long tubes because i dnt want any fabrication issues. I also have the 2005 ls with the fitment issue so i a little limited.
Old Mar 21, 2007 | 11:21 PM
Rush's Avatar
To add to this. If I just a header now, and there has to be adjustments made, will this have any effects on getting a downpipe and exhaust system later? Also, is the pacesetter header good? And whats the main difference between the painted and armor coated? I can get the painted one for $100 less. Also $262.49 is the price for the armor coated at TurboTechRacing, is this the best I can get?
Old Mar 22, 2007 | 12:39 AM
Ceramic, will stay show quality (polished/shiney looking), where as the black paint will burn off over time. I would personally get the ceramic coated.
Old Mar 22, 2007 | 06:28 AM
06Pursuit's Avatar
if your going pacesetter get the armor coated. unless your really straped for cash, way better choice for looks.
Old Mar 22, 2007 | 08:44 AM
^^ agreed
Old Mar 22, 2007 | 10:45 AM
Halfcent's Avatar
I'm old school
No. The Downpipe contains the Catalytic Converter. That's its main purpose. You want it to be separate from the header for that reason. You have to order right. You can buy a header, a downpipe, or a Cat-back. Getting all three is really the only way to go. If you just get a header for instance, the nice freed up flow now just runs into the restrictive downpipe and slows back down again.
Old Mar 22, 2007 | 12:22 PM
07Cobalt's Avatar
1. The description says PaceSetter header DOES NOT fit model with EGR. I have a 07 Cobalt LS automatic trans. coupe. Does it have an EGR? How would I find out?
2. If I bought the PaceSetter header, which downpipe could I go with? I'd like one without a cat, would that be legal and/or would I pass inspection?
Old Mar 22, 2007 | 01:23 PM
Halfcent's Avatar
I'm old school
1. No EGR, your fine.
2. A custom DP is required to use the Pacesetter. Cats depend on your state laws. I'm in Illinois, so I have to have a cat.
Old Mar 23, 2007 | 11:18 AM
djblass's Avatar
hey halfcent wats better a downpipe without a cat or with a highflow cat or regular cat
Old Mar 23, 2007 | 12:23 PM
DoubleClutchin_ION2's Avatar
stick with a stock LSJ manifold.... best bang for your buck, and you can pick em up fairly cheap on here
Old Mar 23, 2007 | 08:43 PM
teh_punk's Avatar
thats what im getting.. should be here beginning of next week. i'll let you know when i put it on.
Old Mar 29, 2007 | 12:19 PM
Blackout06LS's Avatar
My opinion on my pacesetter header....
I went with a cat delete setup, and that swivel joint just plain out SUCKS. It's probably going to take me a full day just to remove it weld everything up add a connection so I can remove it later, etc.
Other than the swivel joint I love it.
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
