header maybe?
header maybe?
will the tsudo header for the 2.2 cav work on our cars? i know that it will bolt to the block but will it line up in the same place as the stock does?
http://cgi.ebay.com/ebaymotors/Tsudo...48227292QQrdZ1
Be wary! The listing is ONLY for Cav's so you'd need to call them to find out if it will fit the Cobalt -- or take a chance (I wouldn't do it), buy it, and try to install it. From the picture they look like they will bolt to the head. But they go up and then back down so only if someone were to test fit them in the car would you know -- might hit the firewall.
no that i think that WILL NOT FIT. i installed a header on my friends cavi (2003 ls sport) and the cavi has alot of room behind the engine (yes the engine is set up the same as ours being intake and exaust) but those headers are made so you can see them from baout.. the poke out the top of the engine.. and nayone who has put a header on the cobalt knows how little room there is back there.. just buy a header for a cobalts
well, based on the pic it looks like it would bolt on ok, but it looks like there may not be enough clearance room... that header looks a lil "chunky" on the back end, and if you look at your stock manifold there's really not that much room for something like that... IF it does fit, it's gonna be an absolute bitch to get on... and what's up with that 3rd piece?? looks like an exhaust tip
No it won't fit. A guy on here already bought one and tried to fit it on his 2.2, but no luck ended up putting it in the classifieds here. Btw the flange will bolt up but thats about it. There's still alot of clearence issues elsewhere
Originally Posted by diablo2007
well i like the header itself would the header work clearence wise and i could just make my own downpipe or if some one has a pic of the area around the header on the cavy
i think that could fit on the Ion...although I think we have a little more engine bay room than the Cobalts.
just measure the amt. of room at the header and then ask the seller for dimensions. if its not too thick it could miss the firewall but I would assume you'd need a custom downpipe.
z28addiction
Sep 28, 2015 12:03 AM
