help me please.
Old Nov 9, 2008 | 10:47 AM
ilovecars's Avatar
help me please.
so i was installing my header and dp and i cant get the header to seal to the head so i sound like a go cart. but the crazy thing is. im leaking coolant like a ****.
if any of you have any ideas as to whats up all i can tell you is its leaking from the back below the header.
what i NEED to know is what kind of coolant to use. i need to get it to the shop and i can make it there if i fill up the coolant.
UGH...why dose this **** always happen to me...
gee thanks.
Old Nov 9, 2008 | 11:34 AM
tonio5555's Avatar
gee thanks.
You may need a new gasket for the header/dp install. As far as coolant, our cars use 50/50 mix of Dex-cool and water.
Old Nov 9, 2008 | 11:36 AM
Dead Zen's Avatar
its leaking coolant because you forced that line to move installing the header
Old Nov 9, 2008 | 04:52 PM
Maven's Avatar
What happened man? what header did you buy? Like Dead said, did you force the heater pipes out of the way???
Your car takes Dexcool(orange) and drinkable water mixed together 50/50. There are also GOLD colored "universal" antifreeze out there that will be fine if you can find Dexcool.
Old Nov 9, 2008 | 06:44 PM
ilovecars's Avatar
i dident think i forced anything to move. and i got an obx header/dp and my stock gasket is only 2500 miles old. i figured it would be fine to reuse.
Old Nov 9, 2008 | 07:38 PM
tru2nrtt777's Avatar
I reused mine and it hasnt leaked and that was over 10k miles ago.
Old Nov 9, 2008 | 08:05 PM
burzumaske20's Avatar
what parts did you come with the obx?Is it a long tube header?If it came with washers,you need more then just 4 washers,longtube headers are a bit trickier to mess with to get it done correctly,you might have a leak from where the gasket is installed too.
Old Nov 9, 2008 | 08:49 PM
Halfcent's Avatar
I'm old school
You have two completely separate problems, treat them that way.
First, remove your header, again, and verify all of your hardware and parts are clean and in good condition.
Then, with it apart, inspect your water pump and pipe. I'm betting you find the leak in the form of a damaged pipe.
Fix what is necessary, and then reassembly using good parts.
Old Nov 10, 2008 | 05:20 PM
ilovecars's Avatar
update. got it back today. what was wrong is my friends a retard and pinched a coolant line in the header so they got that out and coolant stays in my car now but i still have a small exhaust leak im gonna drive on it for a couple days and take it in again hopefully a thicker gasket will be the solution.
it just bothers me cuz it still sounds like a go cart.
on a positive note. i can definitly feel the power in the upper rpm range and the sound is great, nice exhaust note and nice and loud. oh yea NO CEL!
Old Nov 10, 2008 | 05:22 PM
Projekt's Avatar
uh..huh
Old Nov 10, 2008 | 05:23 PM
ilovecars's Avatar
Originally Posted by Projekt
uh..huh
well if you listen in the engine bay its a go cart if you stand outside behind it its nice
Old Nov 10, 2008 | 05:38 PM
Projekt's Avatar
ah ok
Old Nov 11, 2008 | 11:56 AM
Halfcent's Avatar
I'm old school
Friends don't let drunk friends work on their cars.
Old Nov 11, 2008 | 12:37 PM
silver06cobalt's Avatar
For real
But honestly there isnt anything more annoying sounding than a header leak.. Mine was like that for almost a month before i could afford to get it fixed..
Old Nov 11, 2008 | 12:46 PM
MP81's Avatar
I'm assuming this Dexcool is "safe", compared the **** that caused the huge recall on the V6s?
Old Nov 11, 2008 | 12:54 PM
Maven's Avatar
Nope, same stuff.
The biggest issue with the V6s was the gaskets, not the coolant.
Old Nov 11, 2008 | 04:56 PM
ilovecars's Avatar
Originally Posted by silver06cobalt
For real
yes it is quite anoying it sounds like its an old pos now
Old Nov 11, 2008 | 05:24 PM
njg5gt's Avatar
just so you know, it took about 50 miles for my CEL to turn on when i installed my obx setup
Old Nov 11, 2008 | 05:32 PM
ilovecars's Avatar
hmm ill keep an eye on it. thanks
Old Nov 12, 2008 | 05:52 PM
glen229's Avatar
all you have to do is bend the coolant line out of the way... if you were going to do this this soon i would have told you all about it but you told me you werent till spring..
theres a small tab on the left side of the coolant line that you simply have to bend it and rotate the pipe.. it takes a little bit of force at first to get it to move but just rotate it out of the way
its not your gasket you can re use your stock one
speedlimit
Site Development and Help
Sep 25, 2015 08:04 AM
turbaltss08
Sep 14, 2015 10:19 PM
azreal
Nov 10, 2006 10:13 AM
RedBaseBolt
Jul 23, 2006 12:41 PM
