High Flow Cat
Old Apr 15, 2006 | 06:17 PM
FRIARPOP's Avatar
High Flow Cat
Hey has anyone put on a highflow cat? I heard the stock cat is very restrictive, Also if you have upgraded did you get a Cel? I was thinking about this high flow performance cat, think its good?
http://www.sfxperformance.com/parts/PAC800026.htm
Old Apr 16, 2006 | 01:43 AM
NJHK's Avatar
High flow cats are restrictive because it's a catalytic converter...that's its job but it's less restrictive than your stock one. I would only suggest getting one if you're upgrading the rest of your exhaust and keeping the diameter the same (example: 2 1/4" cat-back piping, so you would get a 2 1/4" diameter catalytic converter).
As far as CEL with the Cobalts, I don't know.
Old Apr 16, 2006 | 01:57 AM
FRIARPOP's Avatar
right i plan on upgrading my exhaust to a custom or corsa 2.5'' so i figured i would need a 2.5'' catlalytic converter. Anyone recommend a certain brand?
Old Apr 16, 2006 | 02:14 AM
NJHK's Avatar
I'm assuming you want 2 1/2" for boost (looking at your other post), if you're not, than 2 1/2" is too big for an n/a setup.
Old Apr 16, 2006 | 03:24 AM
vanillathrilla's Avatar
I really like my dynomax
http://www.a-1performance.com/super_...converters.htm
or
www.dynomax.com and then go to master catalogue
Old Apr 16, 2006 | 10:57 AM
dnbguy86's Avatar
If you want a higher flowing cat, just buy the downpipe and catalytic converter off a cobalt ss/sc, same oem fit but bigger piping than whats on the 2.2L
Old Apr 16, 2006 | 11:30 AM
qcpursuit's Avatar
its not a bad thing to switch to an high flow cat but you can have a magnaflow cat for less at gravana.com
avro206's Avatar
I just can't beleive the factory cat is so bad. You want to see awful catalytic converters? Look at car from the mid 70's. Now those were restrictive!
Old Apr 16, 2006 | 11:36 AM
FRIARPOP's Avatar
Why would it be too big? i plan on upgrading to a 2.5 exhaust wouldnt i need to upgrade the cat as well? or would i not have enough back pressure? Im not saying the old cat is crappy or anything i heard it true airflow is around 2'' .
Old Apr 16, 2006 | 06:26 PM
tiny's Avatar
its not about back pressure, its about exhaust velocity
Old Apr 16, 2006 | 10:08 PM
CobaltCoupeCrazy's Avatar
Arrow Check this Thread
This is the link to a thread that I posted about a direct bolt in replacement high flow cat from Random Technology. It's not yet avaible but is supposed to be in the works. The 2.2L has a much more restictive cat than the 2.0L. The 2.2L cat has an outlet that measures just under 2.0".
https://www.cobaltss.net/forums/general-cobalt-68/2-0-2-2-2-4-high-flow-catalytic-converter-16263/
Jan 12, 2016 12:01 AM
no_ss
Oct 18, 2015 11:58 PM
Slick_Nick
Sep 28, 2015 09:15 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
