High Miles, Low Power
Old Feb 22, 2012 | 11:08 PM
BlackSapper's Avatar
Thumbs down High Miles, Low Power
Hey guys..wow I haven't been on here in forever.
So I have an ancient 05 LS with 113k miles on it. You can see mods below. Not that it was really ever fast, but I've noticed a pretty significant power loss the last +-15k miles, especially in the low end.
I do regular synthetic oil changes plus other maintenance. Is the loss of power basically just from the amount of miles on the car, or is there something I can do to get some power back?
It's not that big of a deal really, it's just kind of frustrating I guess. I'm hoping to get a new car next year.
Thanks
Old Feb 22, 2012 | 11:11 PM
05Slowline's Avatar
prob in your head lol is it auto or 5 speed
Old Feb 22, 2012 | 11:12 PM
That could be it too! hahaha. It's a 5-speed.
Old Feb 22, 2012 | 11:14 PM
05Slowline's Avatar
Should be fine, when's last time you did sprak plugs, cleaned air filter, etc.
Old Feb 22, 2012 | 11:17 PM
I put a set of I believe NGK sparkplugs at around 105k, so that should be good. I haven't check the filter on the cai in a long time only because it's a bitch getting to. I don't feel like taking the tire or the bumper off again, unless there's another way?
Old Feb 22, 2012 | 11:20 PM
05Slowline's Avatar
idk bout the cobalts, i know mine just had rivets where my cai was, could just jack it up and release the rivets for the splash guard lol. if you haven't cleaned that, that could def be playing into it a bit though.
Old Feb 22, 2012 | 11:31 PM
nhanson's Avatar
its not hard to yank the plastic guard off quick. All maintenance items have been covered?
1. Air filter
2. Spark plugs
3. fuel filter
4. Spray down MAF with cleaner
5. Seafoam job
Old Feb 22, 2012 | 11:35 PM
royce777's Avatar
you dont gotta take bumper off to get to filter. take out headlight and headlight bucket and you can access it
Old Feb 23, 2012 | 09:54 AM
Axelthered05's Avatar
+1 for this
Old Feb 23, 2012 | 10:03 AM
nhanson's Avatar
I wasnt talking about the bumper. The plastic liner
Old Feb 23, 2012 | 03:24 PM
1. Air filter
2. Spark plugs
3. fuel filter
5. Seafoam job
Holy crap I forgot about the fuel filter. That could be it too. I'll check the air filter soon. Spark plugs are brand new.
Can you explain "spray down MAF cleaner" a little more?
Also..seafoam job???
Old Feb 23, 2012 | 03:25 PM
Okay thanks. I thought I could do that but wasn't sure. The bucket is the piece right below the headlight with like 5 or 6 bolts, right?
Old Feb 23, 2012 | 05:45 PM
nhanson's Avatar
Take your MAF out and inspect it. If dirty get some CRC Mass Air Flow cleaner and spray it down.
Seafoam through your vac line will get carbon off the cylinders. Can also be put in the gas and oil. But i wouldnt recommend with new plugs
Old Feb 23, 2012 | 10:43 PM
BankerBalt's Avatar
hopefully you aren't for some reason losing compression... could be some KR which would drop your timing if it senses it when getting on it a bit
Old Feb 23, 2012 | 11:54 PM
I notice the most power loss right after shifting into second.
Old Feb 24, 2012 | 12:03 AM
BankerBalt's Avatar
do your rpms drop slow or normal when shifting? any CEL? when was the last time your fuel filter was changed?
Old Feb 24, 2012 | 03:35 AM
No rpm difference, no CEL. Honestly it's probably mostly in my head, but it does happen sometimes.
Fuel filter needs to be changed ASAP.
bigdeertz
Nov 17, 2016 09:41 AM
deviance
Nov 24, 2015 05:51 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
OPCrer
Sep 27, 2015 08:11 PM
