how to?
Old Dec 14, 2008 | 04:54 PM
scotch89's Avatar
how to?
i was searching and i couldnt find any thing, but is there a how to on replacing a clutch for us?
Old Dec 14, 2008 | 05:38 PM
Jn2's Avatar
Jn2
yes there i one, but doesnt include pics, should be the same as a cavi clutch swap, try looking on their forums, but i know i saw one here, i thin it was split into 2 parts, if my memory serves me right, it said it was a 8hr job or something
Old Dec 14, 2008 | 05:53 PM
Halfcent's Avatar
I'm old school
Yes, there is one. And there was a lot of criticism of it being WAY too much work. The how-to has you removing a lot of parts that you don't have to take apart. It is not an easy job for the back-yard weekend warrior.
Old Dec 14, 2008 | 06:19 PM
scotch89's Avatar
dam ok thanks
Old Dec 14, 2008 | 06:32 PM
Maven's Avatar
There have been guys that said that it has taken well over 10hours to perform a clutch replacement on their own.
Its billed out as an 8hour job at the shop.
Old Dec 14, 2008 | 06:38 PM
kenhebe's Avatar
You must remove the front suspension, the drive axles, the engine cradle, then drop the motor and transmission as a unit, then seperate the transmission from the motor to install the clutch and then do the reverse process. Much easier said than done. This is a job for professional level mechanics. I would not suggest doing this unless you are very skilled and experienced witht his type of work.
Old Dec 14, 2008 | 07:12 PM
Maven's Avatar
Well, you dont, but thats not the point. Needless to say, it is difficult in the driveway
Jn2's Avatar
Jn2
8hr job, wow, lemme see, the dealership here charges 95/hr, so it would be a 760 job, id pay it
Old Dec 15, 2008 | 03:36 PM
scotch89's Avatar
i thought u only needed to drop the engine on the ss/sc? cause of the sc neck would snap or something, i didnt now u had to do that with the 2.2
Old Dec 15, 2008 | 07:39 PM
Maven's Avatar
You dont drop the engine on either one unless you dont have the proper tools. The way you do it is you support the engine and take out the trans, taking out the whole cradle is a way to do it, but you have to disconnect so many things and open the cooling system, open the a/c(or take off compressor and tie to car) I really dont think dropping the whole cradle is the way to go, unless you absolutely cannot get an engine support, and you have to do it yourself.
Old Dec 15, 2008 | 07:46 PM
THRcobalt07's Avatar
I just did mine over Thanksgiving break and let me say it was a bish!!! If you don't have the proper tools, an engine hoist, and a transmission jack take it to a shop. But if you do have the tools but no lift, prepare for at least a 2 day process. I came into major snags every once in a while and it ended up taking me 3 days to finish. And I believe I have a link somewhere to where there is a manual for the whole installation process if you are still interested in doing it yourself.
