hptuners delete sai?
Old Jun 12, 2015 | 10:56 AM
jay4901's Avatar
hey everyone, my car has secondary air injection and i want aftermarket exhaust headers. i was wondering if you could delete any trouble codes that come up after deleting the system using hptuners? i don't own hptuners yet but i plan on getting it in the near future and i don't want to order new headers if i cant pass emissions with the, and as long as the codes don't come up i should pass just fine since i'm in ct.
Old Jun 12, 2015 | 11:24 AM
umrdyldo's Avatar
If your car is supported then yes you can turn off the codes related to SAI. Then remove the entire system and plug up any remaining holes.
It's against the law, but so are a lot of things.
Old Jun 15, 2015 | 07:46 AM
jay4901's Avatar
when i go to get emissions done can they see that i deleted the codes or will they just not be there anymore?
Old Jun 15, 2015 | 08:33 AM
09CobaltSS1's Avatar
No, they can not see what DTC's are set to no error report or removed. As long as all your emissions monitors are readied and no codes are active or pending, you will be fine. There is no visual inspection in CT either, unless they are otherwise tipped off to do so.
Old Jun 15, 2015 | 08:47 AM
jay4901's Avatar
awesome! also, while on the topic of emissions, do you need to have a muffler and resonator to pass emissions in our state? i have a catted downpipe, but i wasn't sure about muffler/resonators.
Old Jun 15, 2015 | 09:12 AM
As long as you have a cat on the car you're good to go as far as that end of things goes. Again, that's even assuming they do a visual. I've never once had an issue with passing emissions with my car and I'm straight piped, on e47 with quite a few mods. It really all depends on the shop you go to ultimately.
Old Jun 15, 2015 | 10:11 AM
jay4901's Avatar
thanks for the info!!
Old Jun 15, 2015 | 10:17 AM
yellowsupercharged06's Avatar
i did it once with a friend of mines car. You have to make sure you get ALL of the codes there are a bunch of them. There are threads floating around out there on various cobalt forums as to what codes you need to turn off and the correct way to do so.
It was 2 years ago i did it and it was all on the fly so im sorry im not much help.
Old Jun 15, 2015 | 10:54 AM
jay4901's Avatar
i guess i just need to get a list of codes to delete, thanks for the info!
Supercharged06SS
Dec 11, 2022 04:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
Adecker
Oct 20, 2015 09:46 PM
dennis69
Oct 20, 2015 07:39 AM
ThoR294
Sep 28, 2015 05:31 PM
