Installed 2.4 Manifold on my 2008
I just installed my manifold, and the install went smooth. No extra parts needed, but I dont see what the big deal is all about. It pulls a little harder at the top, but.....maybe I was just hoping for a bigger difference....I cleared the "keep-alive memory" so maybe I just need more time for the PCM to adjust to the changes....
Was anyone else kind of just...."eh" about the manifold after the install?
actually. it would.
we would see the typical upward curve @ 6500, rather than the huge drop with the stock intake mani. taking a look at a dyno test of your car would let u very obviously see your power in relation to rpm and the air to fuel ratio being hit at that time. i think the biggest thing your having a problem with is that with PE Delay on stock tune, your not getting the power as immediately as you should.
It seems to be pulling a bit harder now that I have driven it a few days. Im going to do some more bolt ons and leave it at that. FI would be nice, but I just want a fun daily driver....not a race car. :O)
did you follow Mavens how to when you installed this?
also did you need to buy the Spacer Plate Kit?
http://www.crateenginedepot.com/stor...P1820C137.aspx
Positive. I took it off the engine myself. And I did notice a difference, but the initial difference was a bit disappointing...after a few days of driving the high-rpm gain is quite noticeable.
i would imagine ced can sell you just the manifold without the spacer kit
