Installed 2.4 Manifold on my 2008
Old Apr 13, 2009 | 12:29 PM
06_ion2's Avatar
Originally Posted by Red07SSNA
Maybe in IL, I haven't seen a Cobalt in the wrecking yard at all around me.
look for a 2.4 ion same ****
Old Apr 13, 2009 | 03:47 PM
Blk08coupe's Avatar
GM parts direct has it for $86. If it is the right part then I am def. going to be getting it.
Old Apr 13, 2009 | 05:13 PM
Kodatech's Avatar
I got mine from a 2008 Pontiac G6 with a 2.4. Initially I was a bit disappointed with the results. I cleared the KAM when I did the install, and after a few days of driving the high rpm gain is definitely there.
I got lucky and got my manifold for free, off an engine that was run with NO oil...1800 miles on the car and some quick lube center didnt put the drain plug back in.
Old Apr 13, 2009 | 05:43 PM
G5Wisz's Avatar
if i have an 08, should i just get the 2008 2.4 intake mani? or the 07 one which is what crate engine depot sells because on GMpartsdirect, the 2008 2.4 mani is $108 and the 07 is only $86
Old Apr 13, 2009 | 06:39 PM
Red07SSNA's Avatar
06/07 2.4 Manifold PN is 12587878
Old Apr 13, 2009 | 09:45 PM
Blk08coupe's Avatar
Is it also worth getting the 2.4 TB as well as the intake?
Old Apr 13, 2009 | 10:09 PM
06_ion2's Avatar
id say yes if your getting a tune because if you dont tune for the TB it will go into limp mode..
Old Apr 14, 2009 | 05:13 AM
Blk08coupe's Avatar
Why would it go into limp mode? It's just a bigger diameter TB blade and housing right? Still uses the same plug as the 2.2L TB? They are both drive by wire as well? Trying to figure this little car out........
Old Apr 14, 2009 | 08:12 AM
06_ion2's Avatar
it will see more air at the MAP and its not tuned correctly for more air.. more air the more fuel it needs.. drive by wire was the older version of the ecotec.. we now are advanced in technology and use a Electric TB... you need a tune or the computer will freak out because its seeing more air going into the motor.. thus will put it in limp mode..
Old Apr 14, 2009 | 02:21 PM
hugemurph4's Avatar
which blows cuz a 80 dollar mod turned into a 350 doller mod
when i installed mine on my 05 i noticed instantly the first drive...probably the most noticable differance in any mod i have done...besides gm tune
Last edited by hugemurph4; Apr 14, 2009 at 02:21 PM. Reason: Automerged Doublepost
Old Apr 15, 2009 | 01:47 AM
  #36
Blk08coupe's Avatar
I was under the impression that an electronic TB was drive by wire and the older ones were cable actuated.....am I mistaken?
Old Apr 15, 2009 | 10:20 AM
  #37
06_ion2's Avatar
drive by is the cable one.. as in drive by wire.. 05+ ecotecs are electric
Old Apr 15, 2009 | 10:25 AM
  #38
bikeboyben14's Avatar
i always heard drive by wire is electric and the old stuff is just throttle cable as in an actual cable
Old Apr 15, 2009 | 04:12 PM
  #39
Blk08coupe's Avatar
My friend, you are mistaken........let me show you the way.
Drive by Wire
Drive by Wire 2
Hope that clears things up a bit.
Old Apr 15, 2009 | 05:26 PM
  #40
Kodatech's Avatar
Drive by Wire
Drive by Wire 2
+1 ^^
Jan 12, 2016 12:01 AM
patooyee
Oct 15, 2015 05:11 PM
Oct 13, 2015 09:32 PM
justinchinn
Oct 2, 2015 12:18 PM
