Intake Manifold from CrateEngineDepot.com
Ok so CrateEngine Depot.com has an intake manifold for the ecotec engine. it is a fabricated alluminum intake and it accepts a 75mm LS1 Throttle Body. Heres my question. Does anyone have this part installed. and if so how do you like it? I know they also sell the 2.4 intake but i prefer a metal intake over a plastic intake manifold.
Unless you are planning on runnin n02 the plastic one will be more than just fine, by dammit it may be better.
I am pretty sure the plastic is lighter than the metal one...just food for thought
to use the larger tb, you have to tune for it. Otherwise get ready to drive around in limp mode...
or boost. Basically if you're going to stay na you could stay with plastic. Maybe move to the 2.4 intake. If you're going to run nitrous or boost above 7-8psi it would be wise to go to a metal manifold.
True, but I'd rather blow a cheap plastic manifold then break something else that's worthmuch more money.
