Intake Technical Question
Old Sep 21, 2005 | 09:11 AM
chipsgt's Avatar
So, I have my short ram on, and I love it. I probably wasnt going to put on the cold air extension, it just really dosent matter that much to me. My question is this: After removing most of the stock intake parts, I noticed there is still a piece of stock tubing in the hole that the cold air extension would go through. Would it yeild better results if I remove this?
I mean, I am already sucking air like crazy, but would there be any benefit to me actually taking the time to remove this? Or would it be so small of an increase that its not worth doing unless I am going to put on the cold air extension?
Old Sep 21, 2005 | 12:11 PM
05BurntOGSL's Avatar
yep....put your Injen extension on and thats where it goes......
Old Sep 21, 2005 | 06:34 PM
ecoteched's Avatar
if you take it off, there will be more air flow throught that hole. And also a tiny bit of a weight reduction....
Old Sep 22, 2005 | 08:15 AM
chipsgt's Avatar
Great! I will try and do that. Heres my next question. In order to get that tubing out, am I going to have to take the wheel off? I am guessing that it just wont pull out. Is that right?
Or can I work it out of its hole?
Old Sep 22, 2005 | 09:50 AM
i think you have to take your fender well out.....not sure
Old Sep 22, 2005 | 11:01 AM
Blackdeath's Avatar
No, you don't have to take the wheel off. When I installed mine I only removed the plastic wheel well underneath. The wheel was not that much in the way that it had to be removed.
06MetallicBalt
Jul 20, 2025 08:47 PM
brandon04
Oct 21, 2015 07:04 AM
no_ss
Oct 18, 2015 11:58 PM
patooyee
Oct 15, 2015 05:11 PM
