Sounds like an exhaust leak to me.. Cause if it was internal your knock sensors would be cutting power and you would have a serious problem!
(Post 6967972)
Honestly it sounds like a cracked header combine through my iPhone speaker
actually, I did throw a knock sensor code when I drove it today. i'll have to pull the code when I get home
It's P0326 Knock sensor 1 circuit performance
also throwing P0171 System too lean (bank 1) As of now though the knock sensor CEL has turned off |
They said exhaust leak? Lmao, um no, heck no it doesnt
Originally Posted by IonNinja
(Post 6968176)
also throwing P0171 System too lean (bank 1) As of now though the knock sensor CEL has turned off did you upgraded your motor and tranny mount? |
Upgraded trans mounts give u false knock?
So it's not an exhaust leak lol. Ran my OEM LSJ manifold with no downpipe and noise is still there.
The only thing left is something on the bottom end or I was even thinking a really fubar'd TOB. I just can't understand why either of those would cause the car to run lean. At idle my LTFT are like ~27 I'm lost =/ |
(Post 6968435)
What's vacuum at,at idle?
19in. hg
is that coming from the blower? i recall some years back hearing a vid like yours and the guys blower was bad. in his case it was sold to him in that condition. i know i've been outta the game for a minute and i'm just trying to help.
no his is all motor noise. i would check out your bottom end and make sure nothing went bad down there
Seems a tad low. Mines at 20-21 ay idle. You may have a small leak causing the afr issue. As for the noise,id have to hear iit in person .
i wanna say its sc related ..not sure though. thats very odd noise lol
he took the belt off and started the car and it was there.. its got to be in the bottom end
Everything in the bottom end is new except crank main bearings.he's on stock clutch components with tons of miles.
Tob?
Possibly
i expect that. my stock clutch doesnt like the 2.8 at all. so i cant imagine his
Yea his clutch has been through tons of nitrous and now 2.7 pulley on e47
I haven't touched the car in 2 days but I'll check some other stuff today.
TOB was my second guess but other issues are throwing me off |
So I threw the car on ramps and started it, then got underneath...its definitely coming from the engine FML
It sounds just like this to me |
well i would say crank bearings since its the only thing you havent really replaced. but double check and make sure those rod bearings didnt go
Well ninja if it makes you feel any better I have a spare crank that's good and main bearings are only 30 bucks. The crank is 2.2 anything pre 07
