Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.2L L61 Performance Tech (https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/)
-   -   Jn2's goes the easy route (https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/jn2s-goes-easy-route-158768/)
Jn2 Mar 3, 2009 07:11 PM
well i decided to go the easy route and just supercharge my car instead, currently i will use this thread for storing shit so i dont forget how to find it:
Aquired:
m62
intake manifold
Saab intake manifold gasket(p/n 12-786-262)
LSJ tensionor
LSJ idler
26*7*3.5 h/e(way bigger than the cobra, ~50%bigger than the ZZP)
KnN intake(from dayta)
GM stgII injectors/harness (from scott allen)
LSJ TB (from scott allen)
bosh intercooler pump w/pigtail
remote filler cap
10ft 3/4" hose
LSJ single gauge pillar
dual bezel gauge pod
cobalt series boost gauge
cobalt series oil temp gauge
innovate wideband kit
lower manifold bracket
pump bracket
stock belt
275pc electrical connections kit(loom, tape, butt connectors, etc)
Need:
alternator bracket
header/dp( from rico)
3 130mm m8x1.25 bolts
2 60mm m8x1.25 bolts
bunch of other random bolts
trifecta tune
alleged Mar 3, 2009 07:37 PM
when will you make up your mind and stop teasing us!!!!
originaladrian Mar 3, 2009 07:39 PM
how much money in total did u waste?
it must have been over 2 grand on turbos and stupid shit.
dude. just make up ur mind.
i honestly cant take u seriously anymore lol
Perfect.disguise Mar 3, 2009 07:41 PM
Why use a thread to store info that you will have to search pages and pages to find something when you could just neatly store it on your computer?
Jn2 Mar 3, 2009 07:46 PM
lol i know i know, i cant make up my damn mind
lol this is it, this is truly it im going thru with this, i havent wasted much, my first build after i sold evetyhing only lost aboue 150bucks from it, this last one, i lost nothing as it all sold for the same cost i bought it for, and i was planning water/air intercooling so most of the expensive stuff im still using
bc im never on the same computer twice, there is no point, i dont have a laptop anymore, gf is using now since her computer fried, and only use of internet is at work, and on iphone :p so this is the best way to store it all in one plcae until i can get it all one my notes on my phone, plus build thread lol, and like i said above, this is it, no more changing my mind
MP Cobalt Mar 3, 2009 07:48 PM
If I was you I'd just stick with the turbo. N yes you should of thought it through before you bought all that stuff.
WhiteSSBalt Mar 3, 2009 07:50 PM
Didn't you help your friend supercharge that granite blue metallic 2.2? Now your gonna be just like him. I say stick to turbo.
Jn2 Mar 3, 2009 07:58 PM
yes i helped him sc his, so i know how to do this in a weekend, and me and him will nt be running the same set ups, i will be using a 3" pulley not a stock one, i will be running a diffrent h/e, mines going to look less put together :p he used a stock resevoir for his intercooler tanks, im using OTTPs, my engine bay will be more more show orientated than his
alleged Mar 3, 2009 07:59 PM
make sure your on ottp's ass about your orders, joe has had really bad luck
Jn2 Mar 3, 2009 08:02 PM
yeah, im sending them PM's and no response yet >: ( at this rate, idk, i may just drop them off my sig and dispute the order with paypal, i want my wideband, the discount they gave me is not worth a long as wait
MP Cobalt Mar 3, 2009 08:20 PM
build your block a little and put a smaller pulley on it
pykie Mar 3, 2009 08:28 PM
boo :( what do you think your gonna make on the sc?
i wouldnt touch it, might as well get on that TVS to make any decent power.
Jn2 Mar 3, 2009 08:32 PM
on stock engine, a TVS is not the way to go, maybe later on next year, hopefully looking for 230hp on 3" pulley
alleged Mar 3, 2009 08:34 PM
yeah the build is pretty easy, im hoping to do it soon once i get rims and other misc stuff
Jn2 Mar 3, 2009 08:37 PM
welli got the tracking on my wideband per their website, should arrive on friday 3/05/09 same date as the blower, now im debating on powdercoating the blower, rattle canning it like joe did, or polishing it s mooth than paint it
alleged Mar 3, 2009 08:50 PM
just spray it, cheap and easy
pykie Mar 3, 2009 08:50 PM
do you think you will pull off 230?
when a stage 2 s/c makes less then that unless they get somone who knows what they are doing with HP tuners and tune it.
NOvelociti Mar 3, 2009 08:57 PM
garret turbo kit, saves the headache
Jn2 Mar 3, 2009 09:40 PM
well i have more displacement, and higher compression than they do, so ideally i should be able to get more hp/psi than they can on the same set up, just that mine make more heat b/c of the higher compression
MP81 Mar 3, 2009 09:56 PM
Do you need the LSJ Idler? I didn't think you did...
Jn2 Mar 3, 2009 10:41 PM
yes u do, i have done this before, trust me, u need that idler pulley/assembly, its not expensive, none of the belt system parts are, hell nothing in the build is expensive new except the blower, and maybe the intake manifold, ive given it till next month on the 20th, if no one has offered me a intake manifold used i will buy one new, also the betl system stuff new will cost: 221.76+bolts+shipping, so prety cheap, the belt you can get used on here, stgII belt, so yeah, im buying the belt system later this month, and the blower shoudl arrive this saturday
b_faulk75 Mar 4, 2009 07:58 PM
Kinda sad, was gonna say BOOO also but someone else beat me to it, lol... I'm sure the S/C will be a great setup, i personally think from a show stand point the s/c looks better, but a turbo is much, much cooler and in most cases FASTER!!!!.... Good luck with this, keep us posted!:cssNET:
Jn2 Mar 5, 2009 09:55 PM
ok, my innovate wideband came in today, after a hew hrs looking thru the PDF's and the website; i figured out how to wire everything, might make a how to, as there is no real innovate specific one, and i also test mounted the h/e using blocks to hold it up, i lifted it to the point where it will sit, fits literally perfectly witht he stock bumper, so perfect the tabs on the bottom come down, nothing a RKsport lip wont fix :) and now on to the pics; and yes i relize my stock bumper looks like complete utter shit, i havent washed the car in a good 2 months
http://i247.photobucket.com/albums/g...1236307461.jpg
http://i247.photobucket.com/albums/g...1236307511.jpg
http://i247.photobucket.com/albums/g...1236307622.jpg
http://i247.photobucket.com/albums/g...1236307821.jpg
http://i247.photobucket.com/albums/g...1236307875.jpg
http://i247.photobucket.com/albums/g...1236307988.jpg
http://i247.photobucket.com/albums/g...1236308048.jpg
http://i247.photobucket.com/albums/g...1236308095.jpg
***thanks go to OTTP for their helping not make this wideband, lets just say, a financial burden ;)
MP81 Mar 5, 2009 09:57 PM
Good call on the Innovate W/B.
That's what I've been looking at. I want the Cobalt-series W/B, but the Innovate is better and cheaper, just wish it had a silver bezel...
Looks like that big mother of a H/E fits right up in there!
WhiteSSBalt Mar 5, 2009 10:00 PM
These kinda threads make me miss having a job and miss having money :bye:
Build looks like its going well though.
