K&N Typhoon Installed!
Thanks to Kyle my new K&N Intake is now installed. Everything fit perfectly, and I was finally breathing a sigh of relief knowing I wouldn't have to order another intake.
She sounds MEAN! This thing def. sucks more air in than the Fujita did, and the tube is beefy. I'll just have to buy another dry flow filter, since this one is most likely going to throw a cel.
Alright...that's awesome. I might have to buy this intake sometime. I tried to delete the plastic tube only (big hole from the belts formed after it fell) and just clamp a breather on to the rubber tube and I mounted to some piece of metal down below but I was still getting CEL's for the air pump. I wrapped the plastic tube with electrical tape to seal it and clamped it back to the rubber tube and stuck the breather on the end but I still get a CEL every once in a while. I clear it and it's ok for a few weeks but then it comes back on. I don't understand it.
I'll post some videos of this and you can def. hear the sweet sound it makes. My gf even loves it too, which is a plus.
To be honest, since it has the SAI also you hear alot going through the exhaust as well. There is a tad bit of a bubbly groan that goes throughout and out the exhaust. It's pretty sweet. I've read a lot about the SAI and it makes sense because it's meant to push more air directly through the exhaust.
