L61 TB Upgrade Question
So I have done tons of searching and cannot find a clear answer. I have a 2007 LT with a 2.4 Intake manifold and the stock 2.2 Throttle Body. I understandto go with a 2.4 (LE5) TB or LSJ TB you need a tune. My questions are as follows:
1. Is it even worth going with bigger throttle body? (I plan on getting a tune anyway)
2. If yes, is it worth going LSJ Throttle body or just sticking to the 2.4 (LE5) throttle body?
Any and all input would be greatly appreciated
scroll down to the 2.2 N/A and tell me if its worth it.. more air/more power
https://www.cobaltss.net/forums/dyno...thread-194257/
There is no Fe5 throttle body... 2.4l is le5 engine, Fe5 is associated with 2.0 SS balts suspension. Upgrading the throttle body only, will give you minimal gains. Get fully bolted and then get an lsj throttle body and tune
also I will be fully bolted prior to getting my tune; should i get the 2.4 TB or LSJ TB, thats really what im trying to find out
zzp makes the adapter plate for the 2.4 mani, 6 to 8 pin wiring harness, and the LSJ TB all in one package
ThoR294
Oct 4, 2015 08:44 PM
