Light on..HELP! Please
Okay heres my delema...i was driving peacefully and i shifted from 1st to 2nd and then when i go to drop the clutch for 3rd...poof...it was like stepping on air. Afterwards i took it to gm and they fixed it. it was the hydralycs on the clutch and replaced the master cylynder and etc. now just recently this light cam on it looks orange like an engine chassis or something...iunno
can someone please tell me what the deal is???? please please please!
i dont have the manual...gayness...
and i dont know how to do that...
if u look closely there are 2 at the top, one in the center below thopse and its the one to the left of th ehighbeams one...
thats the check engine light
looks like that? take it to a local autozone and have them check the light for you and pull the code(s)
yeah but they have diffrent styles, i changed the pic :p depends on the car some say service engine soon, toher say check some just have the symbol for it...but yeah go to a autozone and have them check the code for you, have them print it out and come post what it is
http://www.fquick.com/videos/MRZ_pulley_start_up/7142
watch that video its me starting the car, you see the yellow one thats on next to the one that say brake, is that the one?
get it checked at autozone or a place with a obd 2 scanner, if its code p0833 its a clutch sensor issue.
i had that code when i occasionally let off the clutch.
what happens is the sensor throws a code and thinks the clutch is still pushed in. the sensor just needs replacing. its right behind the clutch pedal inside the car.
if you have cruise control try turning it on when the code is up on your cluster, if it doesnt turn on it will most likely be that issue ( but sometimes your code will clear but the light will stay on) so your cruise control will work but it still could be that sensor
z28addiction
Sep 28, 2015 12:03 AM
