ls4 TB on a 2.2
most of the lsj guys that have it say it makes the throttle way too sensitive and end up selling it so I don't think it would be helpful on a 2.2
2.4 is pretty much the only upgrade worth it
Definitely be overkill plus you would have to make a custom adapter for your intake mani. ZZP sells one that will allow you to bolt up an LSJ tb but since the LS4 is even bigger than that it would not open properly
actually im going to be running the ls4 quite soon once i get my custom made intake mani that is gasket matched to the motor comes in cause of running nitrous it will allow better flow of it and equal more power
nhanson not being a dick or anything but read my earlier post. my buddy is making me a custom made aluminum intake manifold thats gasket matched to my motor that will fit the ls4 tb perfectly cause im going to be doing some mad scientist **** in the next year*evil laugh*
because if your smart with cars you build your motor from top to bottom and then put turbo kit on. cause if i just slap a zzp stage 3 kit im limited this way i can really open the kit up and run more then a lowsy 10lbs of boost
First off there are many High HP NA ecotech builds on here that have made some decent numbers, i can think of 3 or 4 already especially for the weight to power ration for NA cars. Now go you get the same bang for the buck of going FI? Hell no, but I still had fun doing it.
